Well I for sure like this finally a number to check from the outside, and I
think I will try some oil analysis to look for metal also. I guess if you
start to see metal, you might want to change the torque converter.
>He thinks we are just getting sloppy work. But then I knew he would say
>that. Well, I dont know if this helps or not. He said to tell all of you to
>grab the front of the crank shaft and pull then push. If you can feel about
>.005 of play you should be fine. He also thinks I worry to much. As he
>puts it "you have got one of the best hunks of engine iron GMC ever
>built."
As to worrying too much, Al had a new engine, new tranny, new torque
converter, and exquisite maintenance.......
Some people get the elevator some get the shaft.
gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
>built."
gene
mr.erf
