While driving fown the road the coach engine quit, then restarted itself.
This happenedd several times in aa 6 month period. A couple of time it
died while I was moving slowly, and failed to restart itself.
Putting the tranny in neutral and turning the key did the trick.
There were a few more possible causes suggested, but good old JUNO ate
them before I could check them out, and I don't remember what they were.
Jim's suggestions about connectors in the distributor and the steering
column didn't cure the problem.
If anyone can come up with more possibilities, I'll try to save them
outside of JUNO, so its insatiable appetite can't get them.
I reeely don't want the lady to quit in traffic and not strand us.
Thanks,
Ron C
Ron, more than likely a electrical issue. Probably a loose connector in
the
ignition circuit. If you have HEI, I would remove the coil cover on top
of
the cap and check the plug in connections. That is a frequent offender.
Other places to inspect is where the ignition primary circuit starts at
the
base of the steering column. There is a multi-pin connector there that is
vulnerable to shoes and stuff like that. Also, the starter solenoid where
the starter primary wires hook up.
On Wed, Jun 5, 2019, 5:11 PM Tom Newell via Gmclist
wrote:
> Every old thing I have owned has done this at some point (except the
Alfa
> Romeo, oddly). The Triumph was almost comical, as it seemed to
understand
> that "late-night-middle-of-nowhere" was the time-place to make this
happen.
> Ghosts, me thinks... :lol:
> Good luck,
> Tom Newell
> San Pedro, California
> Proud Citizen of
> Los Angeles, California
> Founded 1781 as
> El Pueblo de la Reyna de los Angeles, Alta California
Thanks,
Ron C
the
of
the
Alfa
understand
happen.
> Good luck,
> Tom Newell
> Proud Citizen of
> Founded 1781 as
