Thanks for the response and input. When I drain the oil out I’ll send it out to get checked. I live in a small town but there’s a big rig shop in town that might be able to help with the oil analysis.
Matt in regards to your question as which shell spun or it shedding material. I can honestly answer that. Both times we were just told that there was debris in the engine. My fault on not being more diligent as to the failure.
Now I do have a new large aluminum radiator from JimK that was installed right before the engine failure and reinstalled after the new engine went in. More so because we couldn’t afford to replace it while we were on the road. Talking with you gentlemen sounds like that could of been a possibility for letting debris get into the new engine. I just don’t know.
Sent from my iPhone
> My education and experience with spun bearings most often points to crud in
> the engine, in your case, if in fact they used ANY part of the oiling
> system from the old engine, no matter how cautious they were, and diligent
> in their cleaning process, it only takes a minimal amount of crud in there
> to start the cascading failure.
> Take one of the hairs from a normal person's head, and split it
> lengthwise. That is the diameter of a particle in a brand new engine that
> will cause havoc.
> S and J sets up every engine that they do on their sim test machine.
> It simulates a running engine, except that a powerful electric motor
> actually drives the crankshaft. They measure the current draw on the motor
> while the test is in progress. They also measure heating on the bearings,
> while a constant flow of new oil flows through the lube system.
> If they had any tight clearances, it is unlikely that they would not
> notice it.
> That being said, "stuff does happen ". I personally just finished an
> install on a S&J engine that they repaired for a customer that was a year
> and 12,000 miles out of warranty. They paid shipping both ways, and rebuilt
> his engine (rings, mains, rods, polished both the cam and crank), etc. for
> $500.00. More than fair.
> Salem, Oregon
> On Sat, Jun 8, 2019, 12:54 PM Dolph Santorine via Gmclist <
>> Jim:
>> Many here use Blackstone Labs for our oil work.
>> Many of us have aviation or racing ties, and “oil work” is essential to
>> either.
https://www.blackstone-labs.com https://www.blackstone-labs.com/
>> They have a spiffy new website!
>> I’m sending a copy of the oil work on my coach so you know what they might
>> look like.
>> You’re either going to have an early failure, or it will take a few miles
>> to get a good picture of what’s going on.
>> Dolph
>> DE AD0LF
>> Wheeling, West Virginia
>> 1977 26’ ex-PalmBeach
>> Howell EFI & EBL, Reaction Arms, Manny Transmission
>> “The Aluminum and Fiberglass Mistress"
>>>> On Jun 8, 2019, at 2:05 PM, Jim D. via Gmclist
>>> Need some input from the engine gurus. 9 months ago we spun the main in
>> our original motor. Had it replaced with an S&J engine in Utah. The shop
>> that
>>> installed the new motor put a remote inline oil filter on the new motor.
>> He was being cautious and didn't want to worry about any let over metal
>>> particulates. Much to our fortune less the 1000 miles later the new
>> rebuilt motor from S&J spun the main. They replaced that motor free of
>> charge.
>>> They said they found metal in the motor but couldn't determine if it was
>> old or again we were just very unlucky. My question is. Should I leave the
>>> remote inline oil filter on the new motor or return the system back to
>> OEM. I'm about to change the break in oil from the newest rebuild and could
>> do
>>> it will I'm under there.
>>> Thank Jim
>>> Jim DeMellia and Jen Radefeld and our cat Ickis
>>> NH natives
>>> 1975 GMC “Palm Beach” ,455, her names Linda
>>> Full time RVers exploring the beautiful and unusual parts of the
>> country.
>>> _______________________________________________
>>> GMCnet mailing list
>>> Unsubscribe or Change List Options:
