My take on necessary gages might be engine vacuum, RPM, oil pressure,
coolant temp, engine battery voltage/amperage, Speed and odometer, and
lastly fuel levels. I have a vacuum gage and Tachometer mounted above the
dash and next to the wrap around glass. A quick glance without taking my
eyes off the road tells me what I think is most important. That speaks
volumes for the annunciation type panels like the digi-panel. If something
is outside the pre-set limits, it yells at you to stop, look, and listen.
Or, it flashes bright lights at you or something. Others might have their
own preferences on the order of importance.
Salem,Oregon
On Tue, Feb 9, 2021, 7:40 AM Randy Hecht via Gmclist <
> So what is critical for he average GMC coach operator to have and what’s
> the best way to acquire it?
> Speedometer
> Water temp
> Oil press
> Amp
> And it would appear fuel is almost optional because of the accuracy of the
> gauge .
> Randy Hecht
> Roswell, GA
> 1974 Canyon Lakes GMC Motor-coach
> > On Feb 9, 2021, at 10:32, Ken Shaffer via Gmclist <
> > I have an IPAD mounted to my dash with RPM, speed, coolant temp, trans
> > temp, battery volts, and fuel pressure. The screen flashes red if
> anything
> > is outside the stated parameters.
> > I had a computer braniac design it for me so I can't tell you how he did
> > it, but i'm sure others on here would understand it. We made the display
> > very simple to read. digital format.
> > The fuel pressure is nice to glance at especially if the motor stumbles
> or
> > something is not running right. Easy to see when the fuel filters are
> > getting dirty and allows time to get pulled over to swap (my tanks were
> > pretty rusty. After cleaning tanks, I still am working out the gunk)
> The
> > battery voltage readout sure was nice when my alternator went out. I
> could
> > see the voltage dropping a tenth of a percentage at a time and knew I
> had a
> > problem long before it was evident. In fact, I had my wife start the
> > generator while I was driving in traffic and I didnt pull over for 100
> > miles at the nearest parts store.
> > Not the cylinder head temp monitor Larry 1st posted about, but I thought
> it
> > was relevant.
> > Ken Shaffer
> >> On Tue, Feb 9, 2021 at 7:54 AM Johnny Bridges via Gmclist <
> >> John, there is one that does the important stuff. No voice though,
> just a
> >> SonAlert to get your attention. It's called a 'DigiPanel'
> >> --johnny
> >> Foolish Carriage, 76 26' Eleganza(?) with beaucoup mods and add - ons.
> >> Braselton, Ga.
> >> I forgive them all, save those who hurt the dogs. They must answer to
> me
> >> in hell
> >> _______________________________________________
> >> GMCnet mailing list
> >> Unsubscribe or Change List Options:
