Engine lubrication
tom geiger
673
So was watching a episode of “Roadkill” and they had purchased a old mazda pickup truck with a 455 in the bed of the truck. If you’ve ever watch
the show, these Frankenstein vehicles are the basis of show. Anyhow one of the host commented that he was not excited about the 455, said it was one
of the worst engines. Called it a boat anchor. I did some research and found some criticism on the way it leaves the bottom end of the engine dry of
oil when run at high rpm for duration of time. What do you guys do to help manage this?
Thanks,
TG
Tom,
First of all these guys on these show have no respect for equipment. They probably buzz the 455 in the truck at a high rpm as a guess 4500 +rpm and beat the crap out of it (tech term). Some 455 have be built for racing and that does require special prep on the bottom end and oil system. Oil weight also makes a difference as I have alway run a 15/50 or 20/50 oil over the years starting with dino oil and then as semi synthetic and then a full synthetic in the last few years. Remember that the 455 was originally spec’ed to use a 10/30 or straight 30 weight oil.
The motor in the GMC motorhome depending on the final drive, tire size and speed never goes over 3000 or so RPM for any extended period of time. Typically if you have a 3.07 gear you’re only running 2350 rpm at 70 ish mph. The 3.55 gear runs 2650+/- at 64/65 mph and 3.66 ratio is typically about 2875 +/- at 63/64 mph. I have had experience in all three ratios. I have run all day long with the 3.66 final at 3000 rpm when I needed to make miles for years and have never had an engine issue and or had oil pressure fluctuations ever in the 20+ years and all my engines weather a 403 or 455/461. My oil pressure has run in the motors that I have use has been right at 50 psi at speed. The 455 was used for years to power big irrigation pumps for hours and hours.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
Michigan
> Thanks,
> TG
The 455 was used in a lot of Jet Boat applications. A trick the boat guys came up with was to tap into the oil return on the side of the heads and run
a direct line down to the oil pan.
Tom McManus
1977 Royale
Chesapeake VA
I was just replying to the question. A 455 can't return oil over 4500rpm for any extended length of time without it pooling in the heads. The return
line was the trick to getting oil back to the pan. My first experience with a 455 was in a Marlin jet boat I renovated many years ago. I ran it at
4800 for lengthy periods with out oil pressure loss. Scary thing. 85mph at 4800. I could shoot a rooster tail 80ft in the air.
http://www.gmcmhphotos.com/photos/member-galleries/p67346-jet-boat-455.html
Tom McManus
1977 Royale
Chesapeake VA
The jet boats (Buelher TurboCraft??) at high revs sustained, and they seemed to survive it. And, pumps and boats are analogous to aviation engines in
this regard, as opposed to ground vehicle service. Constant speed and load,versus variations in both on the road.
Yep understand. He was a younger guy and may not understood how tough those engines were built back then. Good to know it will be fine. Just getting
it over to my house to do some projects on it and one of the first items is change the oil.
Tom, just keep the revs under 5500, and you should be just fine. Let's see?
5500 rpm with 3:07 final drive and stock sized tire circumference, pencils
out to not quite 120 mph. Good luck getting her home!
(VERY BIG GRIN)
On Sat, Jun 13, 2020, 5:56 AM tom geiger via Gmclist <
> getting
> is change the oil.
These engines were not designed for constant Hi revs .
People in the know made sure the return of the oil from the head drained
down easily and also restricted the amount of oil at the push rods.
On Sat, Jun 13, 2020 at 6:45 AM James Hupy via Gmclist <
> (VERY BIG GRIN)
> Salem, Oregon
> > getting
> > is change the oil.
http://www.gmcrvparts.com
J.R. If GM says 10W-30 then what is your logic that 20W-50 is “better”? Seems it would exasperate the gravity drain back issues. Most builders
today don’t like heavy oils as they pull less heat from gearings and heat kills soft bearings
For the application of the slow engine speed ranges that our coaches
operate in, 1800 - 3200 rpm. 20w - 50 is a good call. Need a bit higher
viscosity because of high bearing loads, and large throttle openings at
relatively low rpms. Lots of heat in those piston crowns.
On Sat, Jun 13, 2020, 10:03 AM John R. Lebetski via Gmclist <
> kills soft bearings
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
WE know this, the synthetic oils are considerably better than the
conventional.
Yes, it can leak more, but your getting more protection and dirtying your
drive way.
On Sat, Jun 13, 2020 at 10:10 AM James Hupy via Gmclist <
> Salem, Oregon
> > kills soft bearings
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
James Hupy I disagree. Viscosity is the resistance to flow. With high heat loads you want lower viscosity oil as more flow over the bearings
transfers more heat then on to remove it at the oil cooler. Viscosity and film strength are not the same thing.
Here is an article entitled "Motor Oil Engineering Test Data". It is a long read with lots of repetition. Tests were run on 239 different oils or oils
with after market additives. Oils are ranked by their ability to resist wear. An interesting read as most of the higher ranked oils are of relatively
low viscosity. 5w30's, 0w20's etc. Here is a copy/paste of a section written about viscosity.
SECTION 2 – MOTOR OIL VISCOSITY SELECTION
THE BENEFITS OF USING THINNER OIL:
• Thinner oil flows quicker at cold start-up to begin lubricating critical engine components much more quickly than thicker oil can. Most engine
wear takes place during cold start-up before oil flow can reach all the components (the longer an engine has been sitting, the more of a concern this
becomes), and during warm-up while the oil is still thicker and not flowing as freely as it does during normal hot operating temperature. So, quicker
flowing thinner oil will help reduce start-up and warm-up engine wear, which is actually reducing wear overall.
• The more free flowing thinner oil during cold start-up and warm-up, is also much less likely to cause the oil filter bypass to open up, compared
to thicker oil. Of course if the bypass opened up, that would allow unfiltered oil to be pumped through the engine. The colder the ambient
temperature, and the more rpm used when the engine is cold, the more important this becomes.
• Thinner oil also flows more freely when fully warmed-up to normal operating temperatures. And oil FLOW is lubrication, but oil pressure is NOT
lubrication. Oil pressure is only a measurement of resistance to flow. Running thicker oil just to up the oil pressure is the wrong thing to do,
because that only reduces oil flow/lubrication. Oil pressure in and of itself, is NOT what we are after.
• The more free flowing thinner oil will also drain back to the oil pan quicker than thicker oil. So, thinner oil can help maintain a higher oil
level in the oil pan during operation, which keeps the oil pump pickup from possibly sucking air during braking and cornering.
•The old rule of thumb for desired oil pressure, that we should have at least 10 psi for every 1,000 rpm, pertains to, and is highly recommended for
High Performance and Racing engines. Engine bearing clearances are primarily what determines the oil viscosity required for any given engine. (NOTE:
Viscosity does NOT determine an oil’s wear protection capability, like many people think. Wear protection capability is determined by an oil’s
additive package, which contains the extreme pressure anti-wear components. That is why 5W30 oils can perform so much better than thicker oils in my
wear protection capability testing). But, whatever the bearing clearance, for High Performance and Racing engines, it is best to run the thinnest oil
we can, that will still maintain at least the old rule of thumb oil pressure, even if that means using a high volume oil pump to achieve that. A high
volume oil pump/thinner oil combo is much preferred over running a standard volume oil pump/thicker oil combo. Because oil “flow” is our goal for
ideal oiling, NOT simply high oil pressure. So, one of the benefits of running a high volume oil pump, is that it will allow us to enjoy all the
benefits of running thinner oil, while still maintaining desirable oil pressure.
I have been using two of the higher ranked oils on this list in my personal vehicles including our GMC. I have been very happy with the performance of
0w40 Mobile 1 (ranked #7) used in my Cad 500 powered GMCMH. I am thinking about going to (ranked #4) 5W30 Quaker State Ultimate Durability, dexos 1
– Gen 2, API SN “Plus”, synthetic (green bottle), because of it's higher wear rating. Both of these oils are available at local Walmarts at very
reasonable pricing.
So, the above is all Just My Humble Opinion backed by a few facts that I found on the Web. Other opinions will vary.
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Shafts and bushings are kept separated from each other by something known
as "a fluid wedge" created by the shearing away of oils by the unequal
speed of both surfaces. Viscosity has a bit to do with this, but I am not
sure just how much. Experts have never, ever agreed on this. I used to run
10w-30 H.D. Valvoline Dino oil in my 403 in my Royale, and my low oil
pressure at idle always bothered me. So I switched to 20w - 50 H.D.
Valvoline Dino oil. Much higher now at 140,000 miles on the clock.
Engines in current applications were manufactured with synthetics with
low viscosity in mind. Their clearances are wayyy tightened up compared to
our cast iron dinosaurs. They also rev a lot, lot higher. Over 2 1/2 times
higher than our Oldsmobiles do.
So, most of the writers for road and track and other similar
publications tout synthetic oils, because the companies advertise heavily
in their magazine. If you bite the hand that feeds you, you won't have a
job very long. Synthetics do a bang up job in engines designed for them. No
argument from me on that point.
Like I have always said. Opinions Vary. I appreciate your viewpoint.
On Sat, Jun 13, 2020, 5:15 PM Larry via Gmclist
> oils
> relatively
> this
> quicker
> (NOTE:
> oils in my
> A high
> for
> pressure.
> performance of
> reasonable pricing.
> Larry
> Menomonie, WI.
This topic can go on till the cows come home as there is only a small
difference as to slight chang in viscosity.
Just use sun oil and worry about other more important things.
On Sat, Jun 13, 2020 at 5:41 PM James Hupy via Gmclist <
> Salem, Oregon
> or
> > oils
> > relatively
> critical
> > this
> > quicker
> NOT
> for
> engine.
> > (NOTE:
> > oils in my
> oil
> that.
> > A high
> goal
> > for
> > pressure.
> > performance of
> 1
> > reasonable pricing.
> > Larry
> > Menomonie, WI.
Since the cold viscosity is thinner, it can leak more. Your not seeing the
leak as it is minor and the syn oil can cause more leakage at where it is
already leaking,
On Sat, Jun 20, 2020 at 9:11 AM Grant Schaffer via Gmclist <
> So my question is synthetic oils cause your engine to leak?
> 1974 GMC Sequoia 26'
Grant,
The simple answer is NO.
Unlike many situations, I do not know how this got started. While often times the dynamic viscosity is no different than specified, because the
synthetic lubricants stay where they are distributed better, they often lead to an apparently higher lube oil consumption. This is a result of their
presence on the combustion chamber walls.
I believe this may have started with owners changing to synthetic and them being more conscious of the 6$/quart than they were of the 2$/quart and
that is understandable.
My recent overhaul has only leaked where I made some mistakes and took too long to correct them. (Shortly after restarting, she was loosing a quart
every four hours until I got in there to find and make up the cooler line as it should have been.)
Just finished setting up the injector so it idles correctly. While I was fiddling with it, I set the max RPM to 4500. Should I have a problem on a
hill on S, I'll turn it up a bit - but not much :)
