A while back I asked for some help diagnosing an engine noise problem. As
it turns out the clicking I was hearing came from a single worn out rocker
arm pivot. Now my question. What would cause a single rocker arm pivot to
wear much worse than others? After I pulled the valve cover off, I was able
to wiggle the rocker arms on the # 7 cylinder. Pulled the bolts out and the
convex portion of the pivot was worn about the thickness of the rocker arm
(3/32"). I replaced the 2 rocker arms and the pivot. Cured the noise. Now
I am worried that there must be a cause for the excessive wear. The only
thought I had was the pivot was not getting oil. Only I don't know where
the oil would come from. Anyone have any ideas?
Chip Gremillion
75 Glenbrook
Chip Gremillion
75 Glenbrook
