Engine compartment linings and foam fire extinguishers
voyager
155
The foam fire suppressant is used by the USAF and
probably airports. My brother ( ex-Air Force ) told
Me about it years ago. Said it Is pure protein. You
could eat it if You were out of food. I dont know if
its available commercialy.
Rob Teed
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto:owner-gmcmotorhome]On Behalf Of Mark Grady
> Sent: Sunday, November 29, 1998 7:06 AM
> To: gmcmotorhome
> Subject: GMC: Engine compartment linings and foam fire extinguishers
> Howdy back Scott --
> About foam extinguishers, I'm aware of any, but someone on this list may
> know. I looked in the usual places, but didn't find anything. Halon is the
> most common (computer rooms) then probably Ansul (restaurants) but I'm not
> sure how suitable that is to our application. I haven't
> researched it at all
> as I write this.
> I'm thinking that foam suppressants use a two part chemistry.
> That may be an
> interesting concern about the stability of the compounds given the heat
> that's in the engine compartment (assuming you mounted the supply canister
> there).
> I'm sure we've got an ex fireman on line with some additional
> information....
> Standing by for your findings related to some type of lining,
> both to reduce
> heat and noise as well the likelihood of damage. I'm going to do my
> generator compartment next year.
> By then, this list, which is really a huge distributed knowledge
> processor,
> will have several recommendations.
> Mark Grady
> '77 Kingsley
> N Webster, IN
> mgrady
> > [mailto:owner-gmcmotorhome]On Behalf Of Adohen
> > Sent: Sunday, November 29, 1998 2:13 AM
> > To: gmcmotorhome
> > Subject: Re: GMC: Halon Yukkie Stuff (from a survivor)
> > In a message dated 11/28/98 8:44:39 PM Eastern Standard Time,
> > mgrady
> > > Which is better: the halon system or the ceramic paper or the
> > "insulator"?
> > > Mark Grady
> > > '77 Kingsley
> > > N Webster, IN
> > > mgrady
> > Hi Neighbor!
> > The favorite GMC pest is here. The last week most of my time was spent
> > researching what kind of insulation to put in my generator box
> and engine
> > compartment. Lytherm is made by Lydall Companies. (Lytherm.com)
> > I called the
> > local distributer and talked to him until I thought I would still
> > have enough
> > money left to pay the phone bill. There are 2 thickness we
> > talked about 1/8
> > and 1/4 in., 1530L and 1535L both are good to temperatures to
> > 2300 degrees. I
> > told him the application in which I wanted to use it. He told me
> > that he would
> > not recommend these products for that use because of possible
> delamination
> > from water. He said that some type of fire resistant waterproof
> > layer should
> > be attached first to the naked Lytherm. I am now talking to film
> > makers and
> > laminators to come up with a product which fits the water, fire proof
> > criteria. I will post when I find out more this week.
> > Rather than hylon isn't there a product out there that is a
> > foam like
> > shaving cream that is used in fiting fires?
> > Scott Adohen
> > NEHODA'S
> > BACK YARD
Howdy back Scott --
sure how suitable that is to our application. I haven't researched it at all
as I write this.
I'm thinking that foam suppressants use a two part chemistry. That may be an
there).
information....
Standing by for your findings related to some type of lining, both to reduce
By then, this list, which is really a huge distributed knowledge processor,
Mark Grady
'77 Kingsley
N Webster, IN
mgrady
> To: gmcmotorhome
> mgrady
> "insulator"?
> > Mark Grady
> > '77 Kingsley
> > N Webster, IN
> > mgrady
> Hi Neighbor!
> researching what kind of insulation to put in my generator box and engine
> I called the
> have enough
> talked about 1/8
> 2300 degrees. I
> that he would
> not recommend these products for that use because of possible delamination
> layer should
> makers and
> foam like
> Scott Adohen
> NEHODA'S
> BACK YARD
