You'll probably get a lot of good suggestions, but I'l tell you what I did
20 years ago that's worked quite well ever since: Since I had the engine
compartment empty, including the wheel well liners, anyway, I used "duct
board" to cover every flat surface, horizontal and vertical. Duct board is
a 3/4" thick rigid fiberglass matt covered on one side with an aluminized
mesh. The material is rigid enough that it's used as its name suggests:
To build HVAC ducts -- they just make the ducts from it and duct tape. I
put the covered side down to prevent oil absorption, for waterproofing, and
for thermal protection. The upper, exposed fiberglass matt, I sprayed well
with 3M contact cement augmented here and there with fender washers and
drywall screws. I sealed the exposed edges with aluminum foil duct tape.
I'd feared I'd have trouble with the fiberglass becoming saturated with
water and/or oil, but have had no problem whatsoever -- turns out the
underside of the floor stays pretty clean and dry. If I were doing it
again, I'd cover the exposed side with thin aluminum sheeting. I've
knocked holes in the surface with several things, including pressure washer
spray. But after 20 years, I really have no complaint.
I'd be very reluctant to try to insulate the underside with anything
without gutting the compartment. Just my bias/laziness.
Americus, GA
www.gmcwipersetc.com
On Fri, Sep 27, 2019 at 6:34 PM tonka6cuda6--- via Gmclist <
> Hi folks,
> Im looking for suggestions on the best product to insulate my engine
> compartment for heat and noise BUT i need to do it from inside the engine
> compartment not inside the coach as i dont want to pull all the great
> carpet the PO installed.
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
