Since you live in MN are AGM batteries compatible with cold climates?
> I have one friend that still buys optima batteries for his vw's, and says
> they are still good. If you ever noticed 95% of VW's have a battery size
> hole in the floor under the rear seat where the battery used to sit. So
> when you restore one, you are best to put a AGM in so you don't have to
> replace the floor again.
> What is interesting is optima took the time to explain themselves on their
> website:
https://www.optimabatteries.com/experience/blog/optima-batteries-suck-the-truth
> If I was them, I would of paid for a different URL, so it does not seem so
> biased? Who knows.
> since I live in MN, I know not to let a battery go dead, so that might
> help... but I did have 2 Lead acid go bad on my coach. I bought some High
> cranking amp lead acid starting batterys. I was told that is not always a
> good thing because some of the higher cranking amps in a smaller case, the
> plates can be closer together, and can short out easier. But I used to
> go by the thought that if they sold a 900 cca battery in the same size as a
> 750. I would spend more for the 900. I have seen this also with my
> friends TDI new beetle. It takes a higher CCA and more expensive battery
> then
> the standard beetle. And he is on his 3rd battery, all replaced under the
> warranty time frame.
> Jon Roche
> 75 palm beach
> EBL EFI, manny headers, Micro Level, rebuilt most of coach now.
> St. Cloud, MN
William S. Schurman
box 772806
Steamboat Springs, CO
80477
1978 Palm Beach
TZE168V100258
