I am hoping someone has experience that will be helpful. I have the clip out, the engine is about done, but I also plan to lift the transmission out
to do the filter and inspect the pinion bearing (as that has been recently an issue for some).
Will I be better off if I reinstall the engine and transmission from the top as a unit, or as two separate pieces?
I'm getting there, but it is all going more slowly than I would like. (Of Course)
