Hi folks,
I just bought a 1973 Canyonlands with 79,000 original miles from the
original owner and it appears to be running very well. But as I look at
the engine, my question is what is the easiest way to get it pulled?
Down the bottom or out the door? To get it out the bottom, it seems like
it would require one heck of an angle to jack up the front for
clearance. Out the door appears tight and maybe would require stripping
to the bare block first? Some people on the list are talking about
installing high volume oil pumps and the like but how in the heck do you
drop that oil pan with the trans covering access to the pan. I will be
purchasing the shop manual (s) soon which might help. By the way, does
anyone have a set of manuals to cover the 73? Don't need the
supplemental books which cover later years. If so, please give me a call
or drop an E line and let me know what you want for them.
Thanks, Phil Swanson
1750 South Point Dr.
Bonita, Ca. 91902
(619) 421-7276
Phil
Bonita, Ca. 91902
(619) 421-7276
Phil
