Boy you ask a lot of questions....
The rollers, etc are stainless. Next time you're in town look for an
aircraft parts place... or let your keyboard do the walking. Marine places
may have the same. Rollers replaced the rods. Routing is same as it was but
the rollers were installed so as to not hit the frame.
I'll get you some of the other answers later.
In the middle of extending a wiring harness and the soldering iron is hot.
See yah later.
Heinz
To:
Sent: Friday, March 05, 1999 12:52 PM
Subject: GMC: Emergency Brakes
>Hi Heinz!
>I went to your Gen-set page http://www.bytedesigns.com/gmc/genset.htm and
got
>bored. So, I started to wander around and came across your emergency brake
>system found in your new I believe, table of contents. I had visited this
a
>while back but didn't need to ask questions, but now since I am going to be
>putting my frame back soon I want to install the emergency brake cables
>differently than standard. Presently they run through bent metal rods. I
want
>to make some pulley devices like your installation. Questions: What are
the
>sheaves made out of? Are they Ball bearing? What is the diameter? Hole
size
>and overall. Bracket? What size is the angle, steel or alu? Is the
same
>size sheave used where it attaches to your worm gear device?, this is
where I
>would be attaching my original lever cable.
>Thanks
>Scott Adohen
See yah later.
Heinz
To:
>Hi Heinz!
got
a
want
the
size
same
where I
>Thanks
>Scott Adohen
