If, as I've often contemplated, I installed a linear actuator for the
parking brake it's tension would be applied through a "strong enough"
spring to eliminate adjustment worries.
> I have a pneumatic cylinder beneath the brake pedal (outside) with a tube
> extension enclosing the rod and a chain to the brake pedal. A switch
> selected tiny air compressor supplies enough pressure to pull the pedal
> down with 150 lbf. 6-wheel (10 if towing) parking brakes!
> Admittedly not a "legal", independent system but at least f/r redundant.
> And MUCH more dependable than a line lock since it compensates for any
> hydraulic linkage until both f & r are empty. Its weak point is the
> battery -- I figure the 3 sec run every minute will deplete the battery in
> maybe a month.
> Ken H.
> On Sat, Feb 27, 2021, 12:29 PM Bill Van Vlack via Gmclist <
>> I believe Albert Branscombe is no longer making his kit. The Applied
>> website shows what looks like his kit as being currently unavailable. Re:
>> line
>> lock; A friend acquired a coach with that system and once set, could not
>> release it. Had to briefly bleed a wheel cylinder to release pressure. A few
>> folks are using linear actuators to set the rear drums; downside is that
>> the cable length has to be re-adjusted as brake shoes wear. I drove an ice
>> cream truck in the 60s that had the same lever operated e-brake as our
>> GMCs and it worked just fine holding on a grade in Pittsburgh so that I
>> could
>> go to the back and send milk shakes out of the side window. Shorter truck
>> and just two rear wheels.
>> It's always seemed strange to me that the OEM system relies on steel
>> cables making turns under tension by sliding over a steel hook. More
>> tension,
>> more friction.
>> Bill Van Vlack
>> '76 Royale; Guemes Island, Washington; Twin bed, full (DS) side bath,
>> Brazilian Redwood counter and settee tops,455, 6KW generator; new owner a/o
>> mid
>> November 2015.
>> _______________________________________________
>> GMCnet mailing list
>> Unsubscribe or Change List Options:
