Dave--
Sounds like a good unit --- let me know how the installation goes and how it
performs. BTW, the website you referred to does not seem the be the correct one
for this control???
Gary
North Bend, Oregon Coast
> Gary,
> Don't know if mine is the some as Claudes but I am going to the electronic
> cruise control also. The OEM was'nt working so instead of trouble shooting I
> decided to upgrade. I eliminated a whole bunch of garbage on top of the
> engine (vacuum servo,transducer,speedo cable extention, 1/2 mile of vacuum
> hose, etc). I have an new unit sitting here (after a long hard search) but am
> unable to install it untill I get my coach back from Cinnabar.
> The control switches look exactly like modern OEM versions. Have to cut off
> the end of the blinker switch and install this one over the stub and it holds
> with two little set screws on the backside.
> I worried about not being able to find a unit that senses the speed by
> magnetic pick up for front wheel drive. This unit is slick in that its sensor
> simply screws onto trannys speedo output and the speedo cable screws back on
> to the sensor. It is small, magnets and pickup are sealed from the elements.
> There is a sealed box (5"x4"x3") that has the throttle control cable that
> will have to be mounted in the vicinity of the old servo, probabally on the
> rear wall of the engine compartment. Plug two connetions, supply 12 volts and
> I hope it will be good to go. I will report back on it's performance once it
> is installed.
> This unit is called Ultra Cruise II
> part number on actuator- AUX-250-1316 I paid $192.00
> control switch- 250-3032 $ 34.95
> speed sensor- 250-4153 $ 28.40
> I bought it from GHI in Grand Rapids, Mi. phone (616) 241-3980. They are
> online at www.iserv.net/~ghimta
> Thanks everybody for a great site.
> Dave Meekhof
> 73 Glacier
for this control???
Gary
> Gary,
> is installed.
> Dave Meekhof
> 73 Glacier
