Electro level II questions.
Ken B
16,834
279
83
I have a 78 Eleganza sitting my my hangar with neither rear suspension compressor operational. The owner has an injured back that required surgery 2
weeks ago. So I figured that I would go fix it. I have never worked on an Electrolevel II, So I have been digging through the wiring diagrams for
about an hour and think I have it figured out along with an appropriate diagnostic approach to start with.
I have a couple of simple questions before I go out there and attack this problem. The 1978 diagram shows a 30 amp CB feeding both compressors
through acc position of the ignition switch. Where is that CB located? I am assuming it is behind the glove box.
The diagram also shows 2 relays, (one for each compressor). Where are they located?
See I told you they were simple questions. I could probably find them on my own once I got there but I am playing lazy right now.
Ken B.
Hi Ken, yes the 30 amp circuit breaker is same place as El 1. Top of fuse panel behind glove box. The relays are in the cabinet with the
compressors and are the same ones as the El 1 except wiring is different. The compressors and relays are hot all the time and the photo cell leveling
sensors in the wheel well switches the grounds. The electronic photo cells leveling sensors are now listed on Applied available new.
https://www.gmcrvparts.com/product-p/gm14-14.001.26.3.htm
> surgery 2 weeks ago. So I figured that I would go fix it. I have never worked on an Electrolevel II, So I have been digging through the wiring
> diagrams for about an hour and think I have it figured out along with an appropriate diagnostic approach to start with.
> Ken B.
C. Boyd
76 Crestmont
East Tennessee
Hi Ken,
Its at the very top of the fuse panel behind the glove box, its labeled SUS AIR. I can send you a picture if needed.
Russell
Russell Keith,
1978 E2 "Harry" 403 (still carbureted), Danny Dunn Tranny, Thorley, Stock Brakes w/Remote Vacuum Brake Booster, Quad Bags, Dakota Digital Dash, 6.5 kW
Onan, Dunedin, Florida
I have a spare EL2 compressor that i would sell. I decided to go for a
single unit and tank. Sorry, only 1. You will need two if you're sticking
with the original set up
On Tue, Jul 23, 2019 at 7:13 AM Russell Keith via Gmclist <
> Hi Ken,
> Russell
> Russell Keith,
Will,
Do you have the height controller for sale?
Call me 800-752-7502
On Tue, Jul 23, 2019 at 5:57 AM Will via Gmclist
> > Hi Ken,
> > Russell
> > Russell Keith,
> 6.5 kW
http://www.appliedgmc.com
Sure Jim, will do. I have a working passenger side. The driver side
worked,but the level broke off. Might be repairable. I'll give you a call.
On Tue, Jul 23, 2019 at 10:49 AM Jim Kanomata via Gmclist <
> Will,
> > > Hi Ken,
> > > Russell
> > > Russell Keith,
> Stock
> > 6.5 kW
> > > GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
Ok, thanks.
>> Will,
>> On Tue, Jul 23, 2019 at 5:57 AM Will via Gmclist > >
>> sticking
>> > > Hi Ken,
>> labeled
>> > > Russell
>> > > Russell Keith,
>> Stock
>> > 6.5 kW
>> > > GMCnet mailing list
>> > GMCnet mailing list
>> Jim Kanomata
>> jimk
>> 1-800-752-7502
>> GMCnet mailing list
I might have one of each in the shed.
Len and Pat Novak
1978 GMC Kingsley
The Beast II with dash lights that work and labels you can see!
Fallbrook, CA new email: B52Rule
http://www.gmcmhphotos.com/photos/showgallery.php?cat=4375
www.bdub.net/novak/
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Will via
Gmclist
Sent: Tuesday, July 23, 2019 5:56 AM
Cc: Will; Russell Keith
Subject: Re: [GMCnet] Electro level II questions.
> Hi Ken,
> Russell
> Russell Keith,
kW
This email has been checked for viruses by AVG.
https://www.avg.com
Thanks Russel. I think I can find it. I was just getting prepared for the job before I went and looked at the actual coach. I hate sitting on the
floor in front of that door working on the compressor(s). It takes me forever to get my legs working again.
> single unit and tank. Sorry, only 1. You will need two if you're sticking with the original set up.
Thanks. At this point I have not diagnosed the problem so I have no idea if the compressors are bad. There is a good chance a PO modified something.
Who knows at this point. The PO had been dead for many years.
We have some new pumps for the Electro Level 2
On Tue, Jul 23, 2019 at 11:33 PM Ken Burton via Gmclist <
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
