Paul, before you purchase a new compressor, check the internal solenoid
valve in the head of the compressor. If the solenoid is leaking, you will
lose air pumping capacity, and if the leak is large enough, the compressor
will not be able to reach full pressure. It could be the head gasket, but
that's not likely to give you a leak large enough to bother the compressor.
You can check the solenoid by using a piece of plastic or rubber tubing.
Place one end close to your ear, and move the other one around the head of
the compressor. The solenoid exhausts below the head, where it extends over
the cylinder. The ignition key should be on for the test, and of course,
you want the compressor to stop running so you can hear any leak.
I replaced mine about a month ago. (I got them from Gateway for $61.50 each.
Not cheap, but much better than the cost of replacing the compressor) If
your compressor has failed, we will all be listening eagerly for your
solution.
By the way, when you make your repair(s) check the main solenoid valve
between the compressors and the air bags. I have heard that most are
installed backwards. Mine were. The arrow on the side of the valve should
point AWAY from the bag not away from the compressor.
Good luck.
Scott Shean
78 Royale
Baton Rouge, LA
> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of Bartz, Paul
> Sent: Monday, April 12, 1999 3:42 PM
> To: 'GMC Motorhome Mailinglist'
> Subject: GMC: Electro Level II Compressor
> Anyone had the need to replace one of their Electro Level II
> compressor's??
> If so, what did you obtain?
> Yesterday, I found that my right side compressor is only able to
> develop 80
> psi pressure. Two weeks ago, although slow, it produced the 120 psi I use
> to inflate my four air-bag suspension. Don't believe it is one of the
> solenoid valves.
> Guess I'll have to look at one of the Thomas pumps discussed here back in
> January, since Cinnabar wants $343.00 for a replacement pump. Ouch.
> Paul Bartz
