I'm re-posting this because for some reason it didn't appear after I first=
tried to post it a few days ago.=C2=A0 Please thank Yahoo if you see qu=
estion marks=C2=A0in strange places... A sincere thanks for everyone's su=
ggestions in helping to resolve this problem. I finally found the short i=
n the right tail light, brake and emergency flashers.=C2=A0 Call me "Speedy=
."=C2=A0 It only took a=C2=A0few hours most days for over two=C2=A0weeks=
=C2=A0to trace the short without success.=C2=A0 In the end, it turned out t=
o be caused by a hidden crushed wire running between the body and frame.=
=C2=A0 It was a bad wiring job done by a local RV store soon after I bought=
the GMC in 2001.=C2=A0 Their work was both expensive=C2=A0and bad.=C2=
=A0 Anyway, I learned a long time ago not to use them but, unfortunately,=
=C2=A0their bad work has lived on.=C2=A0 The crushed wire ran between a 10-=
wire connector in the generator compartment to the trailer connection under=
the coach.=C2=A0 The good news is I learned how to trace shorts but I'm no=
t going to come out of retirement and go into Electrical Short Tracing.=
=C2=A0 I took umpteen resistant readings from front to back=C2=A0and bought=
a cable tracer from Harbor Freight.=C2=A0 I also put together a light to p=
lug into the fuse socket that lit when a short was present and did not lite=
when there was no short in the circuit.=C2=A0 These tools helped determine=
that the short was somewhere between the 10-point connector in the left re=
ar and the right tail light.=C2=A0 Getting to the approximate vicinity was =
essential.=C2=A0 Checking wires and connections in the rear, I finally foun=
d the short by pulling wires.=C2=A0 I pulled fairly hard on one of the gree=
n wires.=C2=A0 It broke where it was hidden between the frame and the body.=
=C2=A0 The insulation was gone, the copper wires were crushed.=C2=A0 It was=
obviously shorting against the frame.=C2=A0 Case closed.=C2=A0 My proje=
ct for the next couple of days will be redoing all the wiring the local RV =
store installed.=C2=A0 You live and learn. Thanks again for everyone's he=
lp. All the best,Tom Whitton26 foot updated GMCPaducah, KY
