How I started learning about this stuff was over the hood of model T, then
Model A, then Fords of the 40's and 50's. When they put the valves in the
heads instead of the blocks where they should be, I lost interest in Fords.
I switched to Olds Rockets and Cadillacs, then VW and other Foreign
(european) cars.
Japanese (rice grinders) were held in low esteem in my circle of
friends. Still are, by some.
My formal training started with General Motors Training Centers, then,
Porsche/Audi/ VW/Dasher/etc. Blue Mountain Community College Diesel School,
Mercury OB, OMC, VOLVO PENTA, Honda MC, etc., etc.
It continued until my retirement as a Vocational Instructor for the
Department of Corrections in 1996.
Oh yes somewhere in there was a drag racing addiction, a formal
apprenticeship, partnership in an Automotive Machine Shop, marriage, kids,
etc.
Salem, Or
78 GMC ROYALE 403
> Automotive electrical systems have been an evolutionary process.
> Originally the only electrical concern was ignition. A number of systems
> were tried. Make n break, hit and miss, magneto, dry cell battery, wet cell
> battery, all were tried.
> What was kinda settled on was points and condenser located inside a
> weather resistant housing with an integral rotor and cap with multiple
> conductors to each plug. Initially timing was static, and no advance
> mechanism was used. Then came manually advanced spark, followed by
> mechanical and finally vacuum advance.
> Then, someone wanted headlights so they could drive at night. So,
> batteries were used, then charging systems to keep them charged, and more
> electrical demands led to improvements. Most of the systems were 6 volt.
> As demands grew, voltage increased as did automotive wire harnesses.
> With 12 volt systems, came through the firewall harnesses like our coaches
> use.
> Modern cars? A further step in the process. And the beat goes on.
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> On Tue, Nov 27, 2018, 9:53 AM RICHARD/MARLI SHOOP
>> The vendor to use for this kind of stuff is Waytek Wire or Del City.
>> Either one is totally about 12V wiring. Especially Waytek. They have
>> EATON/Littlefuse fuse blocks as used in current cars and trucks. Several
>> models have a bussed common for all fuses or all separate. They take the
>> now standard Delphi connectors that snap into the fuse holder directly.
>> Pricing is not out of this world either.
>> > On November 25, 2018 at 4:50 AM Ken Henderson
>> > Scott,
>> > Here, you'll find several publications by GMCers which are specifically
>> > about the GMC's electrical system:
http://gmceast.com/technical/
>> > As for those large wiring diagrams, it's not me, but my son, Alan, who
>> > prints and sells them:
https://docs.google.com/viewer?url=http%3A%2F%2Fwww.bdub.net%2FGMC_Motorhome_Wiring_Diagrams.pdf
>> > or
https://goo.gl/3CtDtm
>> > Ken H.
>> > Americus, GA
>> > '76 X-Birchaven w/Cad500/Howell EFI & EBL,
>> > Manny Brakes & 1-Ton, Troy-Bilt APU, etc., etc., etc.
www.gmcwipersetc.com
>> > On Sat, Nov 24, 2018 at 11:51 PM Scott Fippinger <
>> > > I am wondering where I can begin to understand the basics of
>> automotive
>> > > (gmcmh) electricity. Other than knowing what a battery is and the
>> fact that
>> > > it has a positive and negative terminal, that is about the extent of
>> my
>> > > electrical prowess. (Oh yah, fuses, I know when one is blown!!) Is
>> there a
>> > > book or manual or whatever for me to read and understand the basics of
>> > > electrical automotive engineering. Thanks
>> > > _______________________________________________
>> > > GMCnet mailing list
>> > > Unsubscribe or Change List Options:
>> > GMCnet mailing list
>> GMCnet mailing list
