Jim, I would like to talk to those motor mfrs you mentioned. Could you either forward the request to them or send me their contact information?
> We had a Europian manufacture of motors visit us to see if we could install
> them on each wheel.
> We realized that were limited to the diameter of the rear wheels so they
> went back without going futher.
> Eventually they will come up with a more compact unit that can be adapted
> and we might have a coach that can run on battery , Like Jim H says, the
> amount of batteries will be challenging should one want to try..
> > > So just looking at the Proterra specs for their smallest unit - 35ft. It
> > can go 55-72miles on 94-126Kwh of energy.
> > So we'll say that's 63 miles on 110kwh of energy, so that's about an
> > hour's driving. So you would need a generator capable of at least 110kw
> > continuous to keep up with the energy demand if you like hybrid. That's
> > equivalent to 20 Onan's putting out near full rated power.
> > One HP = 746 watts, so 110kw/ 746 watts = 147hp is the electrical
> > equivalent steady for an hour for their electrical consumption.
> > A 100AmpHr 12V battery = 1.2kw so you would need about 100 batteries to
> > drive an hour at this rate, but actually more. Lead acid should not be
> > taken
> > below 50% charge and li-ion below 80%. so even Li-Ion will need about 125
> > batteries. At about 40lbs each that's 2.5 tons to add. 100Amphr batteries
> > are going for ~$750 each so that's about $94,000 in batteries, plus
> > chargers and battery monitor systems.
> > My sister recently bought a VW Golf EV. She took a pic of her power
> > consumption to send me. It was 27.2Kwh/100km, so thats 27.2kwh for 63 miles
> > or
> > about 1/4 of what this bus does. Her diesel VW likely got her 45mpg vs a
> > bus at likely 5-6mpg, so I don't think she is doing very good with it.
> > EV get better city than hyway because they regenerate to charge the
> > batteries while braking with little wind resistance. We do mostly highway
> > with
> > little braking and high wind resistance, so its mostly just a continuous
> > load.
> > I'd say their record miles on a charge was likely at slow speed, no more
> > than 25 mph where the wind resistance is still low and only against rolling
> > resistance.
> > Just my farmboy mechanic, 45yrs in electronic technology way of seeing it.
> > Bruce Hislop
> > ON Canada
> > 77PB, 455 Dick P. rebuilt, DynamicEFI EBL EFI & ESC.
> > Hubler 1 ton front end
> > My Staff says I never listen to them, or something like that
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk mailto:jimk
http://www.appliedgmc.com
> 1-800-752-7502
