So I’ve bought the Applied GMC electric fuel pump and have a question about the bypass valve. The pic I’ve found shows the bypass going around the
fuel filter, not sure why. On Facebook I’ve been told the pic is wrong, should be around pump. If that’s the case, I’m removing the mechanical
pump so do I even use the bypass? Or should I just replace the mechanical and leave it in line? Advice on these matters and maybe an updated photo
would be appreciated
Thom High
1973 Sequoia
Vancouver Washington
Thom High
1973 Sequoia
