Jim,
Thanks for the instructions. I am pretty sure my choke plate is closed
when cold and takes a bit of pressure to move it. Not at home and won't be
back for a bit, but will see if I can work through it when I get back.
Fay
76 Glenbrook
> Faye, if you want to take a stab at setting that choke, this is how you go
> about it.
> 1. Absolutely cold engine. Do not turn on the ignition key. Do not touch
> the throttle. Remove the air cleaner, and look at the choke plate. It
> should be open.
> 2. Touch the throttle with your hand and pull it back a little bit. The
> choke should snap closed. Touch the choke plate very lightly and try to
> open it. If it resists, it is set too rich. It should open with the
> lightest of finger pressure against it.
> 3. To adjust the choke, loosen the three screws on the choke housing. You
> do not need to remove them. The housing should be free to rotate. Turn the
> choke housing in the direction that opens the choke plate, then the
> opposite way, watching the choke plate as you do this. As soon as the choke
> plate reaches the closed position, tighten the 3 screws without moving the
> housing.
> 4. Turn on the ignition, but do not try to start it. Watch the choke plate.
> It should NOT start to open if the engine is not running. If it opens, the
> choke heater is hooked up incorrectly. It should only start to open when
> the engine is running. A convenient place to hook it up is the center post
> of the isolator.
> This should get you going. If not, call me. I can talk you through what
> comes next.
> Jim Hupy
> On Sat, Jul 7, 2018, 11:53 AM Burt and Faye curtis <
> > Chris,
> > I will look into that - could be one of the problems.
> > Thanks,
> > Fay
> > On Sat, Jul 7, 2018, 8:58 AM Chris Geils via Gmclist <
> > > > Thanks for clarifying. I have a one wire choke that gets 15 16 volts
> > when
> > > > engine is running.
> > > Once you get your choke sorted out please check your system voltage
> > > again. Voltage at the battery with engine off should be 12.5 - 12.7 V.
> > > With
> > > engine running the voltage should be 13 - 14.5 V. If it is up in the
> 16
> > V
> > > range you have a voltage regulator that is dying.
> > > Chris Geils - Twin Cities / W Wa
> > > 1978 26' Kingsley w/ very few mods; Headers, PD9040, aux trans cooler,
> > > one repaint in stock colors, R134a, Al rad, Alcoas, 50k mi
> > > _______________________________________________
> > > GMCnet mailing list
> > > Unsubscribe or Change List Options:
