>I am fixin' to install my Caspro EKE. I have printed out all of the posts
>regarding the installation and setup of this unit. I have one question:
>Should I road test the unit with my toad following behind? In other words, to
>set the unit up, sensitivity wise, under worse case conditions, toad + hill???
First: follow emery's suggestion that you put in some male/female
plugs where you can disconnect the EKE if need be.
Second: I don't think it matters that you have the toad or not. You
need a hill that will strain the engine and allow it to ping...
that's when you adjust the thing. Look at the pictures on Gene's site
so you can see the neat place the emery suggested we put mine.
regards to all and happy forth
al
al
