Larry, et all,
Got it installed yesterday. Piece of cake! Took all of about 2 hours and
that's with the mandatory one hour running back and forth for tools (and
beer). Didn't need the diode either. Mounted the module under my seat. It
does get a bit warm but not hot. Tie-wrapped everything nice and neat. Looks
good.
Took about another hour of tweaking (still not done). Pinging was very
noticeable and much more metallic sounding than my exhaust manifold leak so
it was easy to tell when it was detonating! I did notice I got a bit of a
reduction in power on big hills though (which is bothersome) when I had it
setup to stop the ping. I have been fiddling with the timing on the fly
trying to get it just right. Also noticed there is a VERY fine line between
advanced enough to ping under load (with sensitivity turned lowest) and too
hard starting. Retard the timing just a hair and it starts fine but then no
ping even w/the unit on lowest settings. Seems awfully picky but then that's
what JB said too. I'll bypass it, set the timing to just ping and then redo
my adjustments again.
Those that have them... do you know if you can adjust the EKE module on
the fly or does it read the adjustment settings only on startup? I had to
drive and adj so I would always stop and shutdown with each change. Seems
two people would make these adjustments go a whole lot easier.
Nate '75GB (BTW... Dom Herrera was a real hoot!) Omaha
good.
