Some people have raised the body above the frame 1-2 inch.
> Our kits use a thinner base plate and a ring adapter under the Air Cleaner.
> If your friend has a Hi Rise intake, he must raise the center of the dog
> house.
> On Mon, Mar 15, 2021 at 6:29 PM Ken Henderson
>> Dean,
>> I don't understand the problem: IIRC, when I had the 455 with OEM
>> manifold, the Holly Throttle Body and later the GM TB, was no taller than
>> the Quadrajet and so did not require raising the hatch cover.
>> Even with the taller Cad500 installed with the GM TB, I've only had to
>> slightly raise about a 1/2" high aluminum dome over the cutaway plywood
>> hatch cover.
>> Even when I bought the GMC with a Quadrajet on the 455 with an Edelbrock
>> Performer manifold, the hatch was raised by only about 4". I have to
>> wonder what manifold your friend is using that's even taller than that
>> one.
>> Ken H.
>> On Mon, Mar 15, 2021 at 7:41 PM Hanson Email
>> > Anyone know of a very low profile intake manifold for an EFI that will
>> keep
>> > the doghouse from raising its ugly head? Right now the cover raise is
>> about
>> > 6 inches. Thank you PO.
>> > This is for a friend as I am a quad guy.
>> > Dean The Resourceful Norse Hanson
>> > 75 Avion
>> > 73 Painted Desert.
>> > _______________________________________________
>> > GMCnet mailing list
>> > Unsubscribe or Change List Options:
>> GMCnet mailing list
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk
http://www.gmcrvparts.com
> 1-800-752-7502
