EFI return line
hal stclair
923
I'm planning on installing an old Airsensors EFI I have and am looking for a simple way to run the return line. I was thinking of running a y on top
of both tanks at the vent line. It shouldn't interfere with the venting if mounted above the tank I'd surmise. Anyone tried this method? I know the
new systems are nicer and the day tank with pumps installed are nice but this is what I have and plan on using.($$$)
Hal
1977 Royale 101348,
1975 Eleganza II, 101230
1974 Eagle Bus 45',w/slideout
Hal, on the Howell system, I just put a hose barb in the fuel filler neck,
and run a piece of gates barrier hose to it. Works well and does not fill
one tank more than the other one.
78 GMC ROYALE 403
> Hal
> 1977 Royale 101348,
Hal,
Here is a photo of my return line connected to the filler pipe. I used a bracket from a saddle valve with JB Weld around it to make a secure and
leak-proof connection.
The hose behind the bracket was not fastened away from the bracket when I took the photo, so no worries about chaffing the hose.
http://www.gmcmhphotos.com/photos/mechanical/p27749-return-line.html
Bruce Hislop
ON Canada
Hubler 1 ton front end
I have one of those airsensors units also. It worked well for me. Bought it off a customer who wasnt able to tune it on his own and bailed.
It worked pretty well for me. Maxed at ~400hp but wont be a problem for hte GMC
I also ran my return to the fill neck with that bit. Quick and easy.
Invest in a wide band, it will help with the tune.
76 Glenbrook
> Salem, Or
> 78 GMC ROYALE 403
I have the same return setup with my Howell/EBL. While it is true that until I am more than 1/2 empty the tanks go down equally. However, in my
case, when I get low, the tanks do not fill equally. As a result, I have to keep switching tanks back and forth to keep from running one tank dry.
Reminds me of what has to be done in some airplanes I've flown.
Just my experience.
Richard
SE Michigan
www.PalmBeachGMC.com
Coop Roller Cam 455, Howell TBI + EBL, 3.42 FD, Quadra Bag, Macerator, Manny Tranny etc.
> > Jim Hupy
> > Salem, Or
> > 78 GMC ROYALE 403
> Just my experience.
Haven't flown for a while, but what I remember is generally only high wing aircraft have a "Both" option on the tank selector, as a gravity fed fuel
system can pull from both tanks, whereas a pump fed system cannot as a steep bank can expose the fuel pickup on one tank and not the other causing the
pump to draw in air. In situations like figure 8s where you bank from side to side, one pickup would always be exposed, whereas if you are running
one tank only, you at least get fuel half the time ;)
I also have the Howell system with the fuel return running to the fuel filler on my coach. However, I only have a fuel sender on the front tank. The
way I manage the fuel is I run the front tank down low, then switch to the rear. While on the rear tank, excess fuel is returned to the front, and my
fuel gauge "magically" goes up while on the rear tank. When it gets back up to just under a half, I switch back to the front tank and then run it
down till I fill up again. Works well unless driving through the mountains, where fuel can slosh from tank to tank on hills... Then I'm back to
jockeying back and fourth if I decide to run the tanks that low...
(Anyone wanna place any bets that Hal comes up with a way to return the fuel to the tank using it?)
You'd mentioned your coach has a 3rd tank as well, right? Are they 3 divorced tanks, or are all 3 linked like the 2 stock tanks?
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
RJ, my best advice to you would be, stop running on the bottom half of the
tanks. Fill them up first thing in the morning, drive 4 hours, or 200
miles, and fill up again. Drive off the top half of the tanks, and forget
about your fuel gage as well as your selector switch. More important stuff
outside your windshield to pay attention to. JWIWD.
78 GMC ROYALE 403
> neck,
> fill
> > > Jim Hupy
> > > Salem, Or
> > > 78 GMC ROYALE 403
> dry.
> > Just my experience.
> the
> The
> to
> Howell Injection,
> Fort Worth, TX
> > > Jim Hupy
> > > Salem, Or
> > > 78 GMC ROYALE 403
> > my case, when I get low, the tanks do not fill equally. As a result, I have to keep switching tanks back and forth to keep from running one tank
> > dry. Reminds me of what has to be done in some airplanes I've flown.
> > Just my experience.
> fuel system can pull from both tanks, whereas a pump fed system cannot as a steep bank can expose the fuel pickup on one tank and not the other
> causing the pump to draw in air. In situations like figure 8s where you bank from side to side, one pickup would always be exposed, whereas if you
> are running one tank only, you at least get fuel half the time ;)
> The way I manage the fuel is I run the front tank down low, then switch to the rear. While on the rear tank, excess fuel is returned to the front,
> and my fuel gauge "magically" goes up while on the rear tank. When it gets back up to just under a half, I switch back to the front tank and then
> run it down till I fill up again. Works well unless driving through the mountains, where fuel can slosh from tank to tank on hills... Then I'm back
> to jockeying back and fourth if I decide to run the tanks that low...
I'm think I'm going to install a Y at each tanks vent line and use a double return change over valve. Diesels with two tanks all use that style change
over as they require a return as do most EFI's. That will keep fuel drawn from and returned to the same tank. I want to drop the tanks and replace the
fuel lines anyway so putting a couple of Y's on top of the tanks shouldn't be much more of a chore. Mounting the Y's high shouldn't interfear with the
venting as long as I keep the vent line higher than the return. I need to replace the change over valve anyway so again no extra work.
Thank all for their ideas.
Hal
1977 Royale 101348,
Hal,
Here is my idea because of the unique filling design of our tanks. Since fuel constantly travels back and forth between the tanks until you get below
the 7 gallon level (per tank), It make no difference where you dump the return fuel until you get below where 14 total gallons remains.
So let's address only the return when below the fuel level is below 7 gallons per tank. My thought is to simply dump all of the retrun fuel in the
reserve tank. If the reserve contains 7 gallons or more then the excess fuel will travel it's normal route from the reserve to the main tank. This
process will continue until the main tank is completely empty and assure that the same 7 gallons is left in the reserve. At the point of an empty or
near empty main tank you can switch tanks and know that you still have seven gallons left to tun on. Also while in this switched to reserve mode, all
return fuel will still be placed in the reserve tank. So you will get to use the full 7 gallons from there before you have to start walking or hitch
hiking for more fuel.
This method of plumbing requires no additional switching valves and only needs one return hose while assuring that the maximum amount of fuel is
available for eventual use.
Ken B
Hi All,
Have you considered using a Ford dual function reservoir?
https://www.amazon.com/F1uz9b263b-Reservoir-Assembly-Selector-Valve/dp/B0042HFX68
This would work as long as each of your fuel tanks has an internal fuel
pump.
If one of the tanks fuel pumps is on, that shifts the internal valve so
that the fuel return is pointed to the same tank that is pumping the fuel.
Eric
> Hal,
> the
> or
> all
> Ken B
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
This message, and any documents attached hereto, may contain confidential
or proprietary information intended only for the use of the addressee(s)
named above or may contain information that is legally privileged. If you
are not the intended addressee, or the person responsible for delivering it
to the intended addressee, you are hereby notified that reading,
disseminating, distributing or copying this message is strictly prohibited.
If you have received this message by mistake, please immediately notify us
by replying to the message and delete the original message and any copies
immediately thereafter. Thank you for your cooperation.
I believe this valve requires a high pressure pump. It is non-electric and requires pump pressure to operate. From a search it appears Ford had some
problems with it. I believe they switched to an electrically operated valve later. This is IIRC from when I was under my '93 F-250.
For three years I have been using the same kind of system Ken posposes. I also have a surge tank but that is not a required part of the system he
describes. I went to the "return to reserve" system as the reserve tank on both of my jGMC's were badly rusted and the main tanks were good. I
suspect the reserve was never used and crud or water accumulated in the reserve. The return to the reserve should correct that problem. It works. I
can run either tank and not loose my reserve fuel. I run the reserve tank about 20% of the time to keep the pump excersized.
BTW do not trust the fuel gauges. When my fuel gauges read just below half the Onan will starve out. Number of gallons to fill indicates the Onan is
correct and that indicated fuel level just below half is really one quarter.. Both gauges match down to the reserve level. Found this out twice on
some really hot days when the Onan, running two roof airs, suddenly sputtered and died. Dropped the rear down to get gas to the Onan pickup and beat
feet to the nearest gas station. (Note: I did have Onan fuel vapor lock problems getting it started but that is another subject for another thread.)
> Hi All,
> pump.
> Eric
> > Hal,
> > the
> > or
> > all
> > Ken B
> > Ken Burton - N9KB
Steve Southworth
Palmyra WI
Hi Steve,
Yes it requires pump pressure from an in tank low pressure pump. The one
in our 1990 ford van has been working for the past 27 years.
Eric
On Thu, May 4, 2017 at 8:04 AM, Steve Southworth
> some
> works. I
> Onan is
> twice on
> and beat
> > Hi All,
> > pump.
> fuel.
> > Eric
> > > Hal,
> Since
> get below
> the
> fuel in
> > > the
> excess
> tank. This
> assure
> empty
> > > or
> mode,
> > > all
> get to
> hitch
> only
> is
> > > Ken B
> > > Ken Burton - N9KB
> Steve Southworth
> Palmyra WI
> Hal,
> below the 7 gallon level (per tank), It make no difference where you dump the return fuel until you get below where 14 total gallons remains.
> the reserve tank. If the reserve contains 7 gallons or more then the excess fuel will travel it's normal route from the reserve to the main tank.
> This process will continue until the main tank is completely empty and assure that the same 7 gallons is left in the reserve. At the point of an
> empty or near empty main tank you can switch tanks and know that you still have seven gallons left to tun on. Also while in this switched to
> reserve mode, all return fuel will still be placed in the reserve tank. So you will get to use the full 7 gallons from there before you have to
> start walking or hitch hiking for more fuel.
> Ken B
Now that looks like a winner Ken. It would reduce some of the complexity of my method and not require a unique valve. Simple valve replacement if
required down the road. Seems pretty much fool proof which is a REAL consideration. Thank you, Hal
1977 Royale 101348,
