I know CR-12A (Duracool or equivalent) is popular for use in our coaches, but I have a question for other applications. The common info on charging
the GMC system is to charge it ti 15 - 20 psi on the low side with the engine at 1500 RPMs at an ambient temperature of about 85 degrees, right?
Does this method apply to other vehicle applications as well? Hopefully Emery will see this and reply.
The reason I am asking is that I have been running it in my XJ Cherokee for a number of years now (at least 5 or 6) and I just can't seem to get good
cooling out of it. Maybe I am expecting too much out of it in 100 plus degree temps. If I have the charge too low, the compressor shuts down due to
low pressure, and if I add some, it doesn't seem to cool as well. I tried putting the proper amount per the conversion tables, but still can't seem
to get the charge right.
Thanks, I could use some advice here.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
