My house has ridge vents, but not open-cell foam, which would last long
enough. Mine were installed with an expanded metal screen to keep out bugs,
and I've never had a problem with rain (or snow, for that matter).
Temps in my attic are not that hot, but my house also has sizeable gable
vents.
Current trends are driven by cost engineering, but one can specify better
materials.
Rick "the powered fan was removed 25 years ago" Denney
On Fri, Jul 7, 2017 at 9:54 AM John R. Lebetski
wrote:
> The trend is away from mushroom vents and toward ridge vents in new
> construction. The ridge vents are then filled with a strip of open cell
> foam to
> keep bugs and blown rain out. They are then very compromised at venting a
> usable amount of air. My house has full perimeter eve vents and a full ridge
> vent but attic was scorching until I put in 2 attic fans (2 required due
> to attic volume but on one stat). Now the cool air enters at the eves and
> exhausts at fans at top. Jeff the fan man says he sees this all the time
> with ridge vents where the attic is unbearable. They look like they would
> convection flow well but do not. My cooling bills are way down. My
> suggestion is stay away from home center fans even Broan as the first hail
> storm
> ruins the plastic cover and the motors only last a few seasons. Once the
> open frame motors pick up dust and dirt they overheat.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Rick Denney
73 x-Glacier 230 "Jaws"
