If anyone wants to get a copy of the Installation and Operating
Instructions and Parts List for their DuoTherm you can download an
Acrobat file from Dometic's site.
For the model 54615-046 (13,500 btu used on the 77 model and others) go to:
http://www.rv.com/pdfs/19-739pdf
If you have a newer one with the optional heat strip hookup go to:
http://www.rv.com/pdfs/3104919.000.pdf
They should have others on their site if you have a different model
and you can do a search for the model number.
If you want to add the optional heat strip kit you should also
download the template: http://www.rv.com/pdfs/3101527.004.pdf
Now is a good time to add the heat strip to your unit. Camping World
has it on sale for $10.00 with $1.00 shipping on internet orders.
http://www.campingworld.com/ It is usually about $70.00.
If you decide to retrofit this on model 54615-046, you can order the
switch, female plug and decal from a DuoTherm dealer. The switch is
part number 20250.000 and is approximately $13.00. The female plug
is 314471.000 and is under $2.00. The new decal showing the heater
position is 3104083.005 (don't know the cost).
The hookup is shown on the 3104919.000.pdf file.
Emery Stora
77 Kingsley
Santa Fe, NM
Emery Stora
77 Kingsley
Santa Fe, NM
