Driver's side panel?
henry davis
1,344
>Any suggestions on a speaker/light panel that is very brittle and needs to be
>replaced?
You could cut a panel out of piece of luan plywood. It's not the same
finish as the original panels but would work.
>No luck in finding one. The screw was out and when we tried to put
>it back in the thing practically disintegrated. Also, our original 6K Onan is
>not worth repairing according to CalDiesel. We have started looking at new
>generators and were wondering what is the big discrepancy in price between
>the Generac and the Honda? Thanks, Susan
How much do you want for the Onan?
Henry
>>replaced?
Forgot to add that you will also need to mount different lights since the
lamp holder is made of two snap-in pieces that hold the ends of the lamp.
Also, the lamp cover snaps into the plastic as well. I'd suggest a surface
mount cabin light such as used on boats.
The speaker is a rear mounting one - that may give you some clearance
problems since the plastic provides a bit of an inward molding.
Henry
