Drapes Rods and Brackets
marlene meineken
1,859
Ted
I found this information on drapery's.
This is the best information I could come up with in regards to curtains. It
was found in the GMCMI Newsletter #27. It does not give for individual
windows just all windows.
This is for a 26 footer
24 yards of 48" wide drapery plus
6 yards for the center cross curtains (behind driver and passenger seats)
Some patterns have to be matched and may require more material.
If you line them you need
17 yards 48" wide lining and 5 yards for center curtains
27 yards buckrum or stiffening are required for top and bottom
19 yards of 1/2 inch nylon elastic is required for lower pleat carriers
20 yards 1/2 inch twill tape for upper pleat carriers
(our MH has elastic at both top and bottom).
This is the best that I can find at the time this newsletter came out (89)
you could also write to the editor and get additional information on
curtains
Editor was Ralph Luby
It gives the amount of yardage.
If you don't get an answer in regards to the construction of draperys I will
get back to you later after I have a chance to measure ours and give a
description of construction.
Can't help with rods.
Marlene Meineken
To:
Sent: Saturday, March 04, 2000 1:43 PM
Subject: GMC: Drapes Rods and Brackets
> Hi GMCERS!
> Wonder if any one of you like to get rid or sell the drapes rods and
> brackets also the drapes I can use as pattern. Many Thanks!
> Ted
> Louisville, Ky.
> 1976 Palm Beach
