DOT 5.1 Brake Fluid
RJW
1,631
108
63
SE Michigan
palmbeachgmc.com
A couple of years ago, I was en-route in our GMC from Reno, NV (attended a wedding there) back home to Troy, MI via Albuquerque, NM. To add fun and
excitement to the return trip I decided it would be fun to drive through Death Valley as I had never been there. It was April after all and the young
lady at the visitor's center near Lone Pine, California suggested that the drive in a RV would be no trouble in April as trucks do it all the time.
Well the trip down into the valley was way more fun and excitement than I had anticipated. SHE wants no part of that kind of fun in any future trips.
Upon leveling off near sea level the Tire Pressure Monitoring system stated to beep indicating an overheat on the front 2 tires. At the same time I
started to lose quite a bit of braking. Good thing we were level and we had a place to pull over and stop. I got out and found that the newly
installed 80MM calipers were hot enough to smoke. So I figured the DOT 3 brake fluid had been at or near the fluid's boiling point. After I let
things cool, we had normal braking. The rest of the drive through the valley was no problem with brakes but I did have issues with fuel vapor and
ignition that I could describe in a later post. But we did make it back home OK.
During a visit to Dave Lenzi last week to pick up some more parts (his basement is like Disney Land), we discussed my lack of brakes on that trip. He
suggested among other things that I might want to consider DOT 5.1 fluid as it has much higher boiling temperatures than the DOT 3 I had in my system
and was compatible with both DOT 3 and DOT 4 unlike DOT 5.
I am wondering if anyone has an opinion on going to DOT 5.1
Thanks
Richard
SE Michigan
www.PalmBeachGMC.com
How clean of type 3 does the system have to be to put 5.1 in? Is it (5.1) compatible with the o - rings and seals in the coach? It seems the time to
use it would be when you replace the cylinders and calipers... you'd have to remove them to get all the existing fluid out anyway, or turn the coach
upside down to drain them :)
1) if you are boiling DOT 3 you have bad driving habits. You will also cook the grease and glaze linings.
2) silicone based fluids love to leak past seals in my experience.
Remeber, 5.1 is absolutely compatible with DOT 3
For some reason. "they" decided to make the latest version
Of conventional brake fluid 5.1
DAVE KING
lurker, wannabe
Toronto, Ontario, Canada
Johnny B.:
Can you schedule this when I can attend - I want to see that coach upside down!
Mike/The Corvair a holic
Sent from my iPhone
> --johnny
> Braselton, Ga.
GM recommends D.O.T. 3. What you experienced in Death Valley was what we
call Extreme Service. IF your brake fluid was fresh and contained
absolutely NO WATER OR OTHER CONTAMINANTS, when things cooled down, you
should have been fine to continue to use your coach normally. Proceed
downgrade in the same gear that you would climb it. Use the brakes
intermittently, and give them time to dissipate heat between
applications. If you "ride the pedal" continously on downgrades, be
prepared to glaze the drums and rotors unless you use aggressive type
linings like ceramic or semi- metallic or full metallic ones. 12,000 pound
vehicles require driving like a truck. Lots of following distance. Frequent
rest breaks are a really good idea, as well.
On Thu, Feb 13, 2020, 1:15 PM Johnny Bridges via Gmclist <
> --johnny
> Braselton, Ga.
> in hell
Emery had a good post about the 5.1 brake fluid about a year ago. I believe he went with the Wagner brand. There was a lot of good info in the posts.
Scott.
Scott Nutter
installed MSD Atomic EFI
Houston, Texas
5.1 is compatible with dot 3. That means you can have some dot 3 left in
your system with no issues (other than the 3 portion may boil). I switched
my front brake system on my off road bike to 5.1 and that resolved all of
the brake fade conditions I encountered prior.
Sully
Bellevue wa
On Thu, Feb 13, 2020 at 2:01 PM Scott Nutter via Gmclist <
> posts.
> Scott.
> Scott Nutter
> Houston, Texas
Have you ever driven down to Death Valley from California in a GMC? I think I have good driving habits thank you. I don't ride the brakes and try to
give them time to cool between brake applications.
Richard
SE Michigan
Yes, I have driven that exact road. In my GMC. Pulling a trailer. And I
never overheated my brakes. And I have a 1978 Royale. A heavy coach. But, I
have a couple of upgrades that perhaps you do not. 80 MM front Calipers
with Sticky Ceramic lining, and I have different diameter wheel hydraulic
cylinders, which prevents rear wheel lockup. And I use semi-metalic premium
riveted linings. They are noisy, and grabby when they haven't been used
for a while, but they stop the coach very well.
That is about the best that stock brakes can be without reaction arms
and 6 wheel disc brakes. That drop into death Valley is a fair test on
whether your brakes need attention. But, there are much worse hills than
that.
One that comes to mind is is British Columbia, Canada. Near Whistler
Ski resort. 23 miles of continuous downhill and an 18% grade. I did not
stutter. 18%. The most severe test I personally have encountered. We
traveled that one as a group. At least 7 GMCs. Some towing, some not.
Every coaches brakes were smoking, including mine. A butt-puckering
adventure for sure. These coaches were state of the art, 40 years ago. Not
by today's standards.
On Thu, Feb 13, 2020, 2:33 PM RJW via Gmclist
> to
> Richard
> 76 Palm Beach
> SE Michigan
You do not have to change out any parts. 5.1 is not a silicone fluid. It is a glycol based so it it compatible with Dot 3 or Dot 4 fluids. I just sucked out my master cylinder and added 5.1 and then bled the brakes until they run clean.
It is compatible with the rings and seals.
A very simple thing to replace your existing fluid with 5.1 and I highly recommend it.
They found out how to raise the boiling point by the addition of low amounts of borates.
Frederick, CO
> --johnny
> Braselton, Ga.
> Thanks
> Richard
> 76 Palm Beach
> SE Michigan
> that.
> Salem, Oregon
That trip down to Death Valley was a wake up call that my brakes needed attention. It is apparent that 80MM calipers with stock drum (probably not
optimally adjusted) brakes in an over weight vehicle is not enough for dealing with the significant downhill grades often seen in the western US.
That is the main reason that I had a visit to see Dave Lenzi who knows more about brakes than I do.
My question was not about how bad my brakes are, or to be ridiculed about my ability to drive a GMC in the mountains.
I was asking about about DOT 5.1 to help me make an informed decision on whether to I switch to that during my brake system rebuild.
Richard
SE Michigan
Yes, GM recommended Dot 3 but only because Dot 5.1 did not exist at the time.
Brake fluids change for the better from time to time as labs develop fluids with better characteristics, just as Oils and Transmission fluids have changed.
I highly recommend change your GMC over to DOT 5.1.
Frederick, CO
> Salem, Oregon
>> --johnny
>> Braselton, Ga.
>> in hell
John
DOT 5.1 IS NOT A SILICONE FLUID.
DOT 5 is silicone but DOT5.1 is a glycol based fluid and it totally compatible with DOT 2, 3, 4 but NOT with DOt 5.0.
I don’t know why the SAE or DOT names it with a 5 as it is confusing to some (many) people.
Frederick, CO
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Look at this chart and decide what you want to use. I have used DOT 4 in everything from my motorcycles to every on road vehicle own or work on. I
have never tried DOT 5.1 . The numbers in this chart are the minimum boiling points required to meet the DOT standard.
Dry boiling point is what you get out of the can.
Wet boiling point is what you get after the fluid is installed for a couple of years and has absorbed some moisture out of the air.
I suggest that you want the best (highest) wet boiling point that you can find.
I have a cheapy tester (under $10.00) that you can stick in your reservoir and measure the amount of that you fluid has absorbed.
https://epicbleedsolutions.com/blogs/faq/whats-the-difference-between-dot-4-and-dot-5-1-brake-fluid#
I am sorry and apologize to you if you feel insulted by my comments about
"riding the brakes, etc. I assure you that my intention was not to insult
or demean you in any way. We encounter many people here on the net. Some
are novices, with absolutely no experience driving heavy vehicles down
steep grades, and some are more knowledgeable than that. I have no way to
determine which category every person fits into, so I rely upon giving too
much information just to make sure I cover all the bases. Again, sorry if I
hurt your feelings.
On Thu, Feb 13, 2020, 4:13 PM Ken Burton via Gmclist <
> find.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Mr H :p
You never insult any of us with your posts and I for one always look forward
to reading them.
I had the same thing happen to me on my 26ft when I came thru Death Valley one time
and as it has a Manny 1-Ton up front I suspect brake fluid also. Never had another
problem like that since and have put another 10,000 miles on it-guess I should change
over to DOT 5.1 or the new EIS 6 that I just used in my 23ft.
When I put the new master cylinder on my 23 ft last year I used Wagner DOT 5.1 at
$13 per Qt. Was looking for some again this past week the the price is up to
$25 per Qt. That is when I found the Bosch EIS 6 that is supposed to be 10%
better than 5.1 for 13 per Qt so I have switched over to that for now.
Yes I have wondered too why they went with 5.1 instead of 6 as it is easy to get confused
with the 5.0 and 5.1 designations and the two are not compatible.
Bob
Bob Broadwell
75 Eleganza II-Rebuilt performance engine, Manny trans, Manny 1-ton front end, 73 23ft with a side bath getting some updates-both living in Las Vegas
> I have never tried DOT 5.1 . The numbers in this chart are the minimum boiling points required to meet the DOT standard.
OK, I made you a little chart and added in some other options/ brands. For you emailers I have no control on how the columns line up, so I made the
chart with the temps first followed by the type / brands in an attempt to keep the columns readable for you.
Dry(f) Wet(f) Type or brand
401 284 DOT 3
446 311 DOT 4
506 321 Valvoline DOT 4
509 338 Motorcraft DOT 4 Low Viscosity
518 374 DOT 5.1
536 388 ATE type 200 (blue or amber)
What you are interested in is the wet boiling point number and ATE is still the winner there. It should be cheaper than DOT 5.1 .
My thoughts on the subject is you should never be getting the fluid as hot as the dry boiling point of DOT 3. So if the moisture is measured at least
once a year, then you will know when to change fluid. A higher boiling point fluid will not hurt but keeping it dry, testing it occasionally, and
using the brakes sparingly should eliminate your problem.
https://www.amazon.com/ITEQ-Liquid-Tester-Indicators-Calibrated/dp/B076SC377J/ref=pd_sbs_263_t_0/144-1267831-6760043?_encoding=UTF8&pd_rd_i=B076SC377J&pd_rd_r=eab66d98-ecb6-4ad7-b83e-77d602e1b52a&pd_rd_w=wcyNM&pd_rd_wg=5uXUf&pf_rd_p=5cfcfe89-300f-47d2-b1ad-a4e27203a02a&pf_rd_r=3457G2X6SG8DKQTY886S&psc=1&refRID=3457G2X6SG8DKQTY886S
https://www.ebay.com/itm/Brake-Fluid-Tester-5-LED-Car-Vehicle-Auto-Automotive-Testing-Tool-For-DOT3-DOT4/262023966485?epid=1763134336&hash=item3d01d86f15:g:4KYAAOSwozRZyLLi
> > on. I have never tried DOT 5.1 . The numbers in this chart are the minimum boiling points required to meet the DOT standard.
> the chart with the temps first followed by the type / brands in an attempt to keep the columns readable for you.
> 401 284 DOT 3
> 446 311 DOT 4
> 518 374 DOT 5.1
> least once a year, then you will know when to change fluid. A higher boiling point fluid will not hurt but keeping it dry, testing it occasionally,
> and using the brakes sparingly should eliminate your problem.
Thanks for this Ken. Just a FYI. It should be noted about the ATE Super Blue that "It has been determined that ATE Super Blue does not comply with the
applicable US DOT Federal Motor Vehicle Safety Standard for brake fluid, due purely to blue-tint for the color. The federal standard requires motor
vehicle brake fluid to be colorless or amber in color and distribution of super "blue" has been suspended. However, the same Fluid with out the Blue
tint continues to be available!"
The ATE is available in Amber. I've been using this for years and switch it off with the "Valvoline DOT 4". A little harder to see the Amber come
through than it was the Blue, but still works. Blue is available IF you want to get it shipped from the UK, but is technically illegal to use in US.
JWID
Larry
78 Royale w/500 Caddy
Menomonie, WI.
