>I just discovered that the entry door does not close enough for the seal to
>touch the coach on the top or the bottom. The middle area makes good contact
>but not the top or the bottom. I discovered this condition after a rain when
>I found water on a toolbox that was laying on the floor just inside.
>David
This can be caused by a bent door as some have reported. When the
door strap is not on and the door swings open it can bend the center
in and cause the top and bottom to be away from the frame. However,
I have found some time back that often it is worse at the latch side
so it often is not caused by a bent door but rather by a "bulging" of
the sidewall of the GMC by the door opening. I coined the term
"middle age spread" for this some time back. You can tell if this is
the problem by examining the inside of the sidewall near the latch.
If the cabinet side of the refrigerator (assuming the refrig is next
to the door) is pulled away from the wall at the center but touching
at the top and at the bottom then this is your problem. I had
promised Gene Fisher months ago that I would write up my cure for
this for his web site but I had not gotten around to it. I'll try to
do it during this next week.
Emery Stora
77 Kingsley
Santa Fe, NM
>David
Emery Stora
77 Kingsley
Santa Fe, NM
