Hard to get that 36" pipe wrench inside the nut where broken off though
jofarr, soddy daisy tn, 26' canyonland
----- Original Message -----
Reply-To:
To: GMC Net
Cc: John Wright
Sent: 2/26/2020 5:32:28 PM
Subject: Re: [GMCnet] Door repair
________________________________________________________________________________
Ken,
Remember the big hammer and 36" pipe wrench, i can get anything apart!!
J.R.
On Wed, Feb 26, 2020 at 2:34 PM Todd Sullivan via Gmclist <
> Jesse,
> The hardware suppliers and manufacturers are aware of this so typically the
> nuts and bolts are made from different alloys but it’s a question that
> should be asked when sourcing to ensure you don’t end up with a set from
> same grade of stainless.
> The way I discovered this issue was in the removal of stainless truck stake
> pocket retractable hooks. The screws supplied with the hooks were the same
> alloy and upon removal of the hooks I ended up snapping the screws off in
> the hooks. This surprised me as there was no corrosion present and the
> screws were not cross threaded. I few questions later at Tacoma Screw I had
> the answer.
> Sully
> Bellevue wa
> On Wed, Feb 26, 2020 at 11:45 AM Jesse Farr via Gmclist <
> > Now, do they recommend which nut works best with which screw or best to
> > use in plain steel nut without galling ?
> > jofarr
> > soddy daisy tn, 26' canyonlands
> > From: John Wright via Gmclist
> > Reply-To:
> > To: GMC Net
> > Cc: John Wright
> > Sent: 2/25/2020 11:27:56 PM
> > Gaul is the correct definition. I have even used a never-seize type
> > compound on the threads. If you over tighten SS hardware it can be a
> pain
> > to take apart. There are many grades of SS screws and bolts such as
> 316SS,
> > High-strength 316SS, 18-8 SS, 17-4 PH SS, Super-Corrosion-Resistant 316
> SS
> > and 450 SS. McMaster-Carr gives a good definition of each and possible
> > applications.
> > J.R. Wright
> > GMC Great Laker
> > GMCGL Tech Editor
> > GMC Eastern States
> > GMCMHI
> > TZE Zone Restorations
> > 78 Buskirk Custom 29.5' Stretch
> > 75 Avion (Under going Frame up Restoration)
> > On Tue, Feb 25, 2020 at 8:32 PM Todd Sullivan via Gmclist <
> > > If you are using stainless bolts and nut make sure they are different
> > > grades otherwise the bolt and nut will gaul or seize.
> > > Sully
> > > Bellevue wa.
> > > On Tue, Feb 25, 2020 at 5:35 PM Tom Lins via Gmclist <
> > > > They are on order since I had to grind down the heads a bit to get
> the
> > > > door to close without interference.
> > > > Tom Lins
> > > > St Augustine, FL
> > > > 77 GM Rear Twin, Dry Bath, 455, Aluminum Radiator Quad-Bag
> Suspension
> > > > Solar Panel
> > > > Manuals on DVD
> > > > GMC Dealer Training Tapes
http://www.bdub.net/tomlins/
> > > > GMCnet mailing list
> > > > Unsubscribe or Change List Options:
> > > GMCnet mailing list
