Dollar-bill Test
corey
107
This is a super old thread but I thought I'd update for anyone reading here... after getting my timing right, and replacing both mufflers and
resonator, this reversion has stopped. It no longer fails the "dollar bill test". Not sure what it was that fixed it but I'm not complaining
Corey P /
Hilliard, OH /
1974 Glacier 26' /
3.70 FD /
ION Wheels
What is THE DOLLAR BILL TEST?Sent from my U.S.Cellular© Smartphone
-------- Original message --------From: Corey via Gmclist Date: 12/18/20 3:37 PM (GMT-06:00) To: gmclist Cc: Corey Subject: Re: [GMCnet] Dollar-bill Test This is a super old thread but I thought I'd update for anyone reading here... after getting my timing right, and replacing both mufflers andresonator, this reversion has stopped. It no longer fails the "dollar bill test". Not sure what it was that fixed it but I'm not complaining-- Corey P / Hilliard, OH / 1974 Glacier 26' / 3.70 FD / ION Wheels_______________________________________________GMCnet mailing listUnsubscribe or Change List Options:http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
On vehicles with dual exhaust, a dollar bill is held between a thumb and
forefinger on one narrow end of the bill, then dangled in the exhaust
stream, comparing one side to the other. Not particularly of much value on
single exhaust vehicles. Very subjective to interpretation as well. If you
did have a collapsed muffler, the thought would be that the bill would move
much less on that side. For what that is worth, I guess. If the crossover
passage in the heads and intake manifold, it might be more definitive. I
have never used it. Other folks may have different results.
On Fri, Dec 18, 2020, 2:46 PM 78gmcroyale via Gmclist <
> -------- Original message --------From: Corey via Gmclist <
> gmclist> Date: 12/18/20 3:37 PM (GMT-06:00) To:
Thank Jim.=C2=A0 I've never heard about it.Sent from my U.S.Cellular=C2=
=A9 Smartphone -------- Original message --------From: James Hupy via Gmc=
list Date: 12/18/20 5:01 PM (GMT-06:00) To: gmc=
list Cc: James Hupy Subject: Re: [GM=
Cnet] Dollar-bill Test On vehicles with dual exhaust, a dollar bill is held=
between a thumb andforefinger on one narrow end of the bill, then dangled =
in the exhauststream, comparing one side to the other. Not particularly of =
much value onsingle exhaust vehicles. Very subjective to interpretation as =
well. If youdid have a collapsed muffler, the thought would be that the bil=
l would movemuch less on that side. For what that is worth, I guess. If the=
crossoverpassage in the heads and intake manifold, it might be more defini=
tive. Ihave never used it. Other folks may have different results.Jim HupyS=
alem, OregonOn Fri, Dec 18, 2020, 2:46 PM 78gmcroyale via Gmclist wrote:> What is THE DOLLAR BILL TEST?Sent from my=C2=A0 U.=
S.Cellular=C2=A9 Smartphone> -------- Original message --------From: Corey =
via Gmclist gmclist> Date: 12/18/20=C2=A0 3:37 PM=C2=
=A0 (GMT-06:00) To:> gmclist Cc: Corey Subject: Re:> [GMCnet] Dollar-bill Test This is a super old thread but I=
thought I'd> update for anyone reading here... after getting my timing rig=
ht, and> replacing both mufflers andresonator, this reversion has stopped. =
It no> longer fails the "dollar bill test". Not sure what it was that fixed=
it but> I'm not complaining-- Corey P / Hilliard, OH / 1974 Glacier 26' / =
3.70 FD /> ION Wheels_______________________________________________GMCnet =
mailing> listUnsubscribe or Change List Options:> http://list.gmcnet.org/ma=
ilman/listinfo/gmclist_list.gmcnet.org> ___________________________________=
____________> GMCnet mailing list> Unsubscribe or Change List Options:> htt=
p://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org>______________=
_________________________________GMCnet mailing listUnsubscribe or Change L=
There is another "dollar bill test" as well as the trucker C note. We used
to use a dollar bill to check the fitment of doors and trunks. Close the
door or trunk with the bill trapped between in the joint at the seal. Pull
the bill out and note the amount of drag. repeat at several areas of that
panel to verify a good seal.
Trucker C note. When driving at night to not fall asleep hold a $100 bill
out the drivers window pinched between index finger and thumb. Thought is
you won't fall asleep cause you will let go of the bill.
Sully
Bellevue wa
On Fri, Dec 18, 2020 at 3:19 PM 78gmcroyale via Gmclist <
> Thank Jim. I've never heard about it.Sent from my U.S.Cellular©
> Smartphone
> -------- Original message --------From: James Hupy via Gmclist <
> gmclist> Date: 12/18/20 5:01 PM (GMT-06:00) To:
> gmclist Cc: James Hupy Subject:
> Re: [GMCnet] Dollar-bill Test On vehicles with dual exhaust, a dollar bill
> is held between a thumb andforefinger on one narrow end of the bill, then
> dangled in the exhauststream, comparing one side to the other. Not
> particularly of much value onsingle exhaust vehicles. Very subjective to
> interpretation as well. If youdid have a collapsed muffler, the thought
> would be that the bill would movemuch less on that side. For what that is
> worth, I guess. If the crossoverpassage in the heads and intake manifold,
> it might be more definitive. Ihave never used it. Other folks may have
> different results.Jim HupySalem, OregonOn Fri, Dec 18, 2020, 2:46 PM
> DOLLAR BILL TEST?Sent from my U.S.Cellular© Smartphone> -------- Original
> message --------From: Corey via Gmclist gmclist> Date:
> 12/18/20 3:37 PM (GMT-06:00) To:> gmclist Cc: Corey <
> ctpangborn> Subject: Re:> [GMCnet] Dollar-bill Test This is a
> super old thread but I thought I'd> update for anyone reading here... after
> getting my timing right, and> replacing both mufflers andresonator, this
> reversion has stopped. It no> longer fails the "dollar bill test". Not sure
> what it was that fixed it but> I'm not complaining-- Corey P / Hilliard, OH
> / 1974 Glacier 26' / 3.70 FD /> ION
> Wheels_______________________________________________GMCnet mailing>
> http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org>
> _______________________________________________> GMCnet mailing list>
> http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org>_______________________________________________GMCnet
