Does "S" shift position have engine braking?
6cuda61
418
Curious....do the "S" shift position have engine braking as well, unlike "D" which just seems to freewheel the engine on decel down hill.
Reason i ask is i have a long steep grade that really taxes the brakes and i would prefer to just use the engine to help things.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Yes.
Slow the coach with the brakes before putting it in S and then use engine braking to keep you there.
Do not use S to reduce speed, only to maintain it.
IF the coach does start to go faster than you're comfortable with, then apply the brakes to get the speed back under control.
Use the brakes as little as possible but no less.
Keith Vasilakes
Mounds View MN
76 exRoyale
MicroLevelhttp://www.gmcmotorhomemarketplace.com/vasilakes/microlevel_intro.pdf
Sent: Tuesday, July 27, 2021 2:54 PM
Subject: [GMCnet] Does "S" shift position have engine braking?
Rich Mondor,
Brockville, ON
77 Hughes 2600
All gears on the TH 425 have engine braking. It’s just not very noticeable in 3rd. If you switch to a higher numerical gear final drive, all 3
gears will have more engine braking.
John Lebetski
Woodstock, IL
Rich,
The 1977 Motorhome Operating Manual section on the Automatic Transmission (p18) reads:
SUPER RANGE "S" - Used when super performance is needed for increased acceleration in traffic, hill climbing, or "Engine Braking" down-hill. The
selectors lever may be moved from "D" to "S" and Vice verse, under most operating conditions. "SUPER" should not be used at speeds above 75 MPH.
And in the highlighted note:
CAUTION
Before descending a step or long grade, down a mountain or hillside, reduce speed and shift into a lower gear. Use the lower gear ranges to control
speed.
It's interesting that the manual states LOW "L" may be used at any speed (it doesn't have the top speed limitation as above), and the transmission
only shifts automatically into L below ~40 MPH.
Richard
'77 Birchaven TZE...777;
'76 Palm Beach under construction;
‘76 Edgemonte waiting its turn
> Rich,
> CAUTION
> control speed.
> Richard
Very interesting....
Rich Mondor,
Brockville, ON
77 Hughes 2600
Thanks guys...i will for sure downshift after speed reduction....my hope is actually to downshift even before entering the hill as its very close to
the entrance to the campsite.
Rich Mondor,
Brockville, ON
77 Hughes 2600
I remember from TH400 Corvettes you could try to grab first manually at speeds above the 1-2 shift point but it would lock you out until speed was
acceptable. The TH350s would not lock you out. The TH425 is of course kin to the 400.
John Lebetski
Woodstock, IL
I do t know, i remember getting reverse at 60mph. That was exciting!
Sent: Tuesday, July 27, 2021 6:20:13 PM
Subject: [GMCnet] Re: Does "S" shift position have engine braking?
John Lebetski
Woodstock, IL
Don't leave a guy hanging, Keith - what the hell happened???
Richard
Ha ha ha, the Olds 442 did a LOT of engine braking, the rear tires squealed like nothing Ive ever heard before.
But the transmission and all parts seemed no worse for wear!
Sent: Tuesday, July 27, 2021 7:02 PM
Richard
Originally the 442 indicated 4 barrel, 4 speed, and dual exhausts. Or
something like that. And yes indeed, it would turn the tires. Worked on a
bunch of those. That 4 speed was almost indestructible. Hell for strong.
Salem, Oregon
> From: Richard
> To: gmclist
> Richard
I seem to remember that someone on this list
posted that the transmissions were tested during
development by jamming them into reverse at
highway speed. Development continued until the
transmissions would survive that treatment.
D C "Mac" Macdonald
Amateur Radio K2GKK
Since 30 November '53
USAF and FAA, Retired
Member GMCMI & Classics
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
k2gkk + hotmail dot com
Sent: Tuesday, July 27, 2021 22:01
Salem, Oregon
> From: Richard
> To: gmclist
> Richard
A number of years ago I talked to trans expert Manny Travao about this issue. He spoke to the parts in the trans that transmission braking can be hard
on. (can't remember what they are anymore) He advised me that brakes are cheaper and easier than transmissions to replace. So what I've done since is,
on long downhill interstate grades, I start at the top at 55mph and allow the coach to get to 65mph. I then brake to 55 and let it coast to 65. That
intermitant braking allows the brakes to cool between braking episodes while keeping speed reasonable. On long steep 2 lane grades, depending on the
grade and how winding the road is where I have to slow to low speeds, I will then use the trans to assist braking. JWID
Larry
78 Royale w/500 Caddy
Menomonie, WI.
> hard on. (can't remember what they are anymore) He advised me that brakes are cheaper and easier than transmissions to replace. So what I've done
> since is, on long downhill interstate grades, I start at the top at 55mph and allow the coach to get to 65mph. I then brake to 55 and let it coast
> to 65. That intermitant braking allows the brakes to cool between braking episodes while keeping speed reasonable. On long steep 2 lane grades,
> depending on the grade and how winding the road is where I have to slow to low speeds, I will then use the trans to assist braking. JWID
Been doing that as well but this hill is a bad one.....its about 2.5 miles down and 14% grade.
Rich Mondor,
Brockville, ON
77 Hughes 2600
Yes.
The THM400/425 has:
No engine braking in 1st gear drive range.
Engine braking in 1st gear Low range.
No engine braking in 2nd gear drive range.
Engine braking in 2nd gear "S" range
Engine braking (slightly) in 3rd gear.
HTH
Rick Staples, '75 Eleganza, Johnstown, CO
"Advice is a dangerous gift, even from the Wise to the Wise, and all paths may run ill." -Tolkien
According to my sources, putting the transmission in "S" engages
the band holding 2nd gear and elevates the hydraulic pressure.
Normally in "Drive" when shifting to second, there is a sprague
that engages in the forward direction(no engine braking).
When shifting to 3rd the sprague overruns and the direct clutch
holds the input and output shaft together.
The "L" works the same way only for first gear.
Here's a link to a diagram of the TH400 which is similar:
http://www.turbo-mopar.com/forums/attachment.php?attachmentid=39900&d=1338520896
Bill Wevers GMC49ers, GMC Western States
1975 Glenbrook - Manny Powerdrive, OneTon
455 F Block, G heads
San Jose
TH425 has no energy saving era freewheel clutches so it is engaged in all gears, except for converter slip The friction material wear occurs only
during the shift events. Once in a lower gear, there should be no friction material slip i drive it as if it were a manual in mountains. If you rely
on brakes and you use them up with heat soak, then what? I choose the lower gear preemptively, then apply brakes only as needed to limit engine
overspeed with very short applies and long off intervals. I beg to disagree with Manny here (and on disconnecting the GM designed kickdown which I
have connected as stock) as overheating brakes can warp drums and rotors and break down grease leading to future fails. Remember that even Mobil 1
grease is only rated to 305F by Mobil. My trans has just past 100K mark no problems.
The long grade you speak of at 14% is a first gear grade taken below 30 MPH. In S it will run away.
John Lebetski
Woodstock, IL
Wear on the "S" clutches can be limited somewhat by matching engine RPM'S
to approximately what they would be in "S" before you engage the
transmission manually.
If your coach lurches and rpm's climb suddenly, you just wore off some
clutch lining. Try to minimize that if possible.
Salem, Oregon
On Thu, Jul 29, 2021, 7:25 AM John R. Lebetski
> which I
> no problems.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
This is a good explaination.
I also think that manny means don't use the transmission to slow the vehicle from say 65 to 40, I don't think hes saying to use S to stay at 40mph
Sent: Thursday, July 29, 2021 9:12 AM
John Lebetski
Woodstock, IL
When I go downhill in S using engine braking, it's a bit disconcerting listening to the pop-pop-pop from the engine ...normal or not?
Larry
Larry - Victoria BC -
1977 Palm Beach 40,000 miles, PO said everything working but forgot the word NOT. New Atwood fridge, water heater & furnace. New SS exhaust system,
6000w Onan, Iota Converter, R134A A/C, New fuel lines & heat exchange hoses
