Distributor seized up, ( DATA )
Bob Dunahugh
2,784
4
3
I told Ken Shaffer last night. To mark a stick. As to the distance from the top of the intermediate oil pump shaft. To the top of the engine block. At the distributor hole. He then came to my house this morning. So, we could compare the distance between his 455. And a rebuilt 455 that I have laying around here. On an engine stand. Ken's shaft is .470-inch higher in the block than mine. Ken S intermediate shaft is 8.062 in. Ken H has measured two shafts. At 8.125, and 8.187 in. So, Ken S saft is the shortest already. Then there's another issue. By shimming the distributor up. The distributor drive gear is running .470 in higher than it should be. In relationship to the cam gear. Not good. I need to put some bluing on the driven gear. Just to see how bad it is. (The gear pattern will be on the very end of that driven gear.)
As another note. When the engine is running. The distributor drive gears. Are pulling the distributor main shaft down. So, what stop/stops? Are keeping that main shaft. Down ward forces. From damaging the pick-up coil? I need to take a good distributor apart. I use to have some around. But Ken Saffer has destroyed ALL of them. GRIN. I've said for about a year now. That something is up with that new oil pump. That Ken S installed back then.
Engines, drivetrains, and suspensions are my thing. With all the engines that I've built over a lot of years. This is truly a new one.
Bob Dunahugh
78 Royale since 2003
4 real COPO Yenkos
Ken S had to go to a wedding today. When he gets free. I'm going to use my inspection camera. To get a closer look in there from the top. May need to look inside the oil pan.
Bob Dunahugh
Sent: Saturday, September 11, 2021 10:43 AM
Subject: RE: Distributor seized up, ( DATA )
Bob Dunahugh
4 real COPO Yenkos
Problem is NOT in the distributor! It is the drive shaft, and the spring
clip that is supposed to be located in that free zone between the top of
the oil pump and the engine block. I suspect that you could just get hold
of the distributor drive shaft, and a slight pull could have it in your
hand. Which is NOT HOW it should be. It should remain in the engine when
you invert the engine like you do when torquing the crank bearings, etc. It
is usually the next to the last thing that I install when buttoning up the
lower end of an engine.
Been bitten by that gremlin once, a long time ago in a far away land
known as my foray into the automotive machine shop business with an
alcoholic partner. But, that is at least a two beer story!
Salem, Oregon
> back then.
> Bob Dunahugh
> 4 real COPO Yenkos
Jim,
You're correct: I examined a brand new shaft today, which had the stop in
place (actually 2 push-on spring washers back-to-back). Since Ken Shaffer
can pull his shaft out, those washers are no longer in place. Then I found
among my jump a used shaft with those washers also missing (including scars
where they'd been pulled off). That shaft shows, below the previous stop
washers' location, wear where it seated about 1/2" into the oil pump. At
the other end, there are scars from about 1" seated in the distributor
shaft.
My question now is, WHY is the stop necessary, other than for assembly, as
you described? With the oil pump limiting downward motion and the
distributor preventing upward travel, WHY are the washers essential?
Just curious, really,
> Jim Hupy
> Salem, Oregon
> block.
> in
> shortest
> year
> > back then.
> > Bob Dunahugh
> > 4 real COPO Yenkos
They are only there to keep the shaft from falling out when the engine is
inverted, as I previously described.
Now the $64,000 dollar question is, Do we really need those washers?
Short answer is, no, if you are not inverting the engine. So, we
probably are good to install the shaft with NO WASHERS, drop in the
distributor and check for end play. If you have some, button it up and
fuggitabout it.
If you are anal like me, and strive for perfection in engine
building, you would pull the pan and oil pump, install the shaft with the
spring washers in the correct position, button it back up, and be not 1 bit
better off for the effort. But that is just me. Please use your best
judgment here.
Salem, Oregon
> Jim,
> shaft.
> Ken H.
> It
> the
> land
> > Jim Hupy
> > Salem, Oregon
> > block.
> have
> > in
> > shortest
> The
> the
> the
> drive
> stop/stops?
> pick-up
> around.
> > year
> > > back then.
> > > Bob Dunahugh
> > > 4 real COPO Yenkos
> > > GMCnet mailing list
