Peer,
Once that you beat on it you need to replace it. No telling what or if you
did damage to the dizzy, just not worth it. The HEI is a very good setup,
but the cost will be somewhat higher that just replacing the points style
dizzy and adding the pertronix. You still end up with the stock style air
cleaner. How old are your wires? The plugs are the cheap part of the
tuneup. See shortcut for suggested plugs. For those of you that need
spark plugs for your generator look at the generator guide at the end of
the automotive section.
http://www.gmcmhphotos.com/photos/data/7181/Spark_Plug_Application_Guide1.pdf
Which every way you choose both are very good alternatives.
J.R. Wright
GMC Great Laker
GMCGL Tech Editor
GMC Eastern States
GMCMHI
TZE Zone Restorations
78 Buskirk Custom 29.5' Stretch
75 Avion (Under going Frame up Restoration)
On Location in Tucson, I don't do Winter!
On Sun, Jan 19, 2020 at 4:05 AM Peer Oliver Schmidt via Gmclist <
> This morning I tried again. Hitting it on the top with a hammer. Got it
> out. No idea how much damage I did cause, or why it didn't get out in
> the first place, but it is out now.
> Question:
> Go HEI (new distributor, new wires, spark plugs and new air filter housing)
> Or go with JimKs Pertronix suggestion?
> Best regards
> Peer Oliver Schmidt
> PGP KeyID: 0x4196BF22
> '76a 26' Eleganza II - Virginia, US
> '73 23' Sequoia - Schleswig-Holstein, Germany
J.R. Wright
GMC Great Laker
GMCGL Tech Editor
GMC Eastern States
GMCMHI
> Question:
> Best regards
> Peer Oliver Schmidt
