Dinette set, Cream/Beige color
ScottC
444
252
63
Northern Indiana
I have a dinette set I am not going to use, not sure what year/model it came out of but it is a cream/beige color and does NOT have a "notch" for front step. It is in great shape. I have a couple different tables for it also.
Make Offer!
Don't be bashful, I will consider any offer!
Thanks
Reactions: Inogame
Dumb question, is this for the back of the coach or the middle of the coach?
There are no dumb questions with a GMC, I do not have the answer, hopefully somebody will chime in. All I know is I bought the dinette and matching couch/bunk but the dinette does not have a notch in the steel frame for the front step. I was going to cut and weld the notch but decided we need the extra room for our Shxt (Stuff) lol.
These look like my GM upfit set behind the passenger seat. Rear ones in mine have to accomodate the water and generator enclosures, so no bottom frame to speak of.
Confirming Tyler is correct. Scott's is a side dinette / double bed.
I picked up a rear bedroom set from a parts coach - doesn't have the lower extended frame.
Scott did say that neither of the frames has the notch for the step, so they can't be for the 26-3 setup. I've had 3 coaches with that setup, and they all have the big notch for the step. It keeps one of the benches from sitting upright on flat ground when you set it down--they want to tip over.
Also, if they were for the rear dinette, they wouldn't have legs at all. It's for a different arrangement of some sort.
You know what's weird, is on this rear bath model the front step is omitted from the drawing. This isn't actually possible, right?
Every other floor plan drawing I'm seeing shows the front step, and shows the dinette benches overlapping the front step.
In any case, Scott's dinette set looks like a nice pair if someone had a custom floor plan to work with. I wonder if they started life as two rear benches from a side dinette?
Reactions: Kendra and ScottC
I think Tyler might be right also, It is hard to see in that picture but it appears to be on a large pedestal, I have seen others where that whole passenger side up front was a elevated. But a closer look and the couch looks even with the dinette.
Paul, your 26 rear bath diagram I think was only available from Coachmen...their schematics and other documents are much less polished than the GM stuff. Wiring diagrams are hand drawn with misspellings. Likely just dropped a line in the diagram. I own a rear bath and it has the regular step up front.
I might be intrested myself it he’s too far
I can deliver within an hour or so, also we might be able to stop by Great Lakers Rally in Shipshewana, IN, we also plan on going to rally at Algonac, MI, in Sept. I have dinette, dinette table, louvered cabinet doors, fiberglass bath unit, stainless side molding, old heater box, new Furrion stove/oven etc. If you are looking for something else let me know I might have it.
Wood version? I am not familiar. I’d be interested in what that looks like too. Done it go in the reverse of the coach? If you have anything you unsure just shoot a picture and I’ll see if it’s something I’m interested in.
