Dimmer switch
>No thoughts on moving the dimmer switch to the turn signal lever?
>Herm
>'78E
The lever & links used work the dimmer switch is a little complex to install
into the GMC column, an easier solution would be to obtain late model steering
column and use it to replace the GMC column, the trick is finding an compatable
column. I,ve done this with my El Camino, but have not tried it with our 73
GMC..
John & Brenda Szalay
73 GMC PD
Currently Coachless, high & dry in Louisville
73 is at Jim Bound's place for a facelift..
tummy tuck and manicure. :)
>If there is no GM switch that will operate turnsignals and dimmer that will
>fit in the GMC column, another possiblity for a dimmer switch would be to
>mount a small momentary push button switch on the side of the column and have
>its wires lead down to a latching relay which would turn on and off with each
>push of the switch.
That sounds like an excellent option, when I,ve had GM columns apart,
the switch itself is mounted on the outside of the column about halfway
between the dash and the floor, and is operated by a stiff wire OR a wire
rope/cable up to the turn lever itself.
73 GMC PD
