DigiPanel Question
SteveW
567
44
28
Greetings from Southern California !!
Might any of you fine folks know the details of the "high-speed solid-state engine-temperature sensors" used on our DigiPanels ??
I'm contemplating the installation of a proper temperature sensor port on my transmission pan (and probably a drain plug) and would like to install a
typical sensor rather than the "on a bolt" sensor that the DigiPanel currently uses.
And - considering the same strategy for water temperature too.
Thank you for all of the expertise shared here.
Steve W
1973 23 Yellow
Steve W
1973 : 23'
Southern California
Steve.
I believe Summit Racing sells all the weld on Bung plugs you need. I installed one on my oil pan, trans pan and final drive cover. All worked out
well.
There are also after markket plugs which I am sure will do just as good.
Good Luck and take care,
Tom K.
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D., Micro Level, Howell EBL-EFI Spark Control, Macerator, York Air Compressor, 6 Wheel Disc, Quadra Bag, Onan W/Bovee
Ignition
I am not familiar with the digipanel, other then it does have bolt on sensors.....
weld on bungs for the tranny pan are easily bought from napa, summit, or amazon.... and I recommend that for 2 reasons. 1. tranny temp sensor.
2. works as a drain plug as well!
Jon Roche
75 palm beach
St. Cloud, MN
Applied GMC now sells the DigiPanel. They can refer you to a technical guy who may be able to assist with your question about the senders. As far as
the trans temp, consider getting a finned aluminum pan from ragusarv.com -- they have a fitting built in along with a drain plug. The Ragusa pan is
reported to help with cooling although some folks don't like it because it protrudes a bit lower than stock, increasing the risk of impact damage.
Christo Darsch
GMC Nor'easters
1977 Eleganza II - "The Komet"
3.50 Power Drive, Disc Brakes, Alcoas
Weymouth, MA
I have a Ragusa finned aluminum transmission pan, and it has a drain plug
as well as a plug for a temp sending unit, which I also use. Transmission
temp rarely moves the needle. That finned pan works very well and it has an
extra quart capacity. A good investment as far as I can tell.
I also removed the final drive pan and welded in a bung for a temp.
sensor. That one makes me nervous. Final drive temps exceed 300 ° Farenheit
on heavy uphill climbs. Before I had the temp sensor, I rarely even thought
about final drive temps. I use a synthetic final drive lube as well as ATF.
CHEAP INSURANCE.
> Christo Darsch
> GMC Nor'easters
> Weymouth, MA
Which ATF do you recommend?
> CHEAP INSURANCE.
> Salem, Oregon
> guy
> is
> it
> > Christo Darsch
> > GMC Nor'easters
> > Weymouth, MA
*David Herbert*
Steve,
I think you are asking about the actual DigiPanel temperature sensor parameters. If I recall the DigiPanel does not use a standard sensor setup such
as the 0-90 ohm GM sensor, but rather uses the temperature vs current gradient of a common transistor E-B junction. It doesn't use a temp sensor chip
such as a LM34.
I looked at one of mine but the markings had been ground off. Try a 2N3904 emitter-base junction and compare it to an OEM DigiPanel sensor and see
how close it is.
Just my 2 cents
Bruce Hislop
ON Canada
I use Valvoline Synthetic. It was what Manny recommended in my
remanufactured transmission. I suspect that other brand names would work as
well. But, that is the name brand that I have always used. Brand loyalty
and all that, I guess.
> Steve,
> such
> chip
> such as a LM34.
> see
> how close it is.
> Just my 2 cents
> Bruce Hislop
> ON Canada
