For those of you odering the digi-panel, suggest you buy an additional sensor
for the transmission. I did for bout $8 and I added a small switch which I use
to change from one cooling line to the other. That way I can measure the cool,
and hot lines from the trasmission by flicking a switch. I used one of the
miniature switches and used the blank hole next to the on off switch to make the
connection. Works great.
al
> dlowry:
> actually thetemperature of a
> bolt mounting the thermostat housing. Wouldn't this
> provide areading
> higher than the coolant which at that point is
> attempting todraw heat away
> from the engine, and thus provide a warning well
> before excesstemp had
> actually been reached? >>
> response ---> If I understand correctly - placing the
> sensor on the thermostat housing - has a distinct
> advantage when the overheating is a result of coolant
> loss - the GMC temp sensor may no longer be emersed in
> the coolant - and thus slow to react -whereas the bolt
> would reflect the change -- by measuring ENGINE TEMP
> In a message dated 8/17/1999 12:51:35 PM,
> dlowry:
> Second, the reading for transmission temp is actually
> the temperature of a
> trans pan bolt. As I understand it, the fluid in the
> pan,after having been
> cooled by whatever trans cooler is being used, is as
> much as50 degrees
> cooler than the fluid being pumped to the cooler,
> whereaccurate readings
> should be taken. Since the meter does not change from
> green toyellow until
> 250, and to red with an alarm until 300, won't the
> tranny becooked long
> before the panel warns of trouble?
> Response -- re-read the original post -- the prefered
> method is to attach the digi-panel sensor to the TRANS
> COOLER input line -- because the pan is to slow to
> react.
> Any other tech question please call DIGI-TECH --
> Art Woodell
> 916 687-6905
> Pete Papas-->http:// >>
> Pete -- good response. I would add that heat is not "drawn away" but it
> rather is transfered from the hotter point to the cooler point. This is
> really sematics with the bulk of the engine, but in some other cases is more
> critical.
> As far as placing the transmission sender, the output tubing of the
> transmission would seem to more accurately reflect the temp of the fluid as
> it just leaves the tranny. When looking down into the open hatch at the left
> side of the tranny there are two tubes. The inner one is the output and goes
> to the bottom of the radiator's built in transmission cooler. The left tube
> comes back from the top of the radiator's built in cooler.
> Emery Stora
> 77 kingsley
> Santa Fe, NM
al
> dlowry:
> provide areading
> dlowry:
> much as50 degrees
> react.
> Art Woodell
> 916 687-6905
> critical.
> Emery Stora
> 77 kingsley
> Santa Fe, NM
