Johnny,
The "standard" Digi Panel uses the OEM pressure sensor; however, Art can and does supply one with a dedicated separate sensor which
can be "T'd" off the OEM sensor on the block.
USAussie - Downunder
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Johnny Bridges via Gmclist
Sent: Wednesday, September 21, 2016 11:50 PM
Cc: Johnny Bridges
Subject: Re: [GMCnet] Digi-Panel update
Pressure sensing is a bit of a problem. You can use the stock (unreliable any more) sensor, or you can use a solid state sensor but
must gin up apressure connection - a move fraught with potential peril. Temps are relatively easy by comparison.
Cc: Johnny Bridges
