Digi-Panel Calibration?
gmcnet1
Member
Apr 23, 2019
103
16
I just replaced a broken engine temp sensor on my PO-installed Digi-Panel, and as with the old sensor (before it broke) the temp reads about 25
degrees low. My estimate is based on a reading from an IR thermometer pointed at the sensor which is attached to one of the thermostat bolts. My
analog gauge reading (non-stock) is comparable to the IR reading.
Can the Digi-Panel temp reading be calibrated, or is there some other common issue that might cause this symptom? Maybe a dirty connector at the back
of the Panel or something?
Christo Darsch
GMC Nor'easters
1977 Eleganza II - "The Komet"
3.50 Power Drive, Disc Brakes, Alcoas
Weymouth, MA
Surface temp of the item and the actual temp at the sensor tip could vary a large amount as you are reading surface temp compared to the liquid temp.
JR Wright
> Christo Darsch
> GMC Nor'easters
> Weymouth, MA
The IR reading is also subject to emmissivity errors. All surfaces emit different amounts of IR for the same temp
Sent: Tuesday, June 2, 2020 9:23 PM
Cc: John Wright
Subject: Re: [GMCnet] Digi-Panel Calibration?
JR Wright
> Christo Darsch
> GMC Nor'easters
> Weymouth, MA
Automotive gages and warning lights, buzzers, etc. are notoriously
inaccurate. They approximate a S.W.A.G of actual readings. They are
extremely voltage sensitive, something that varies a goodly amount in a 40
year old vehicle. What they do a fair job of, is changes in what is
considered normal. As in no oil pressure where there used to be plenty, or
overheating.
On Tue, Jun 2, 2020, 7:48 PM Keith V via Gmclist
> From: Gmclist on behalf of John Wright
> via Gmclist
> To: gmclist
> Cc: John Wright
> JR Wright
> > On Jun 2, 2020, at 7:28 PM, Christo Darsch via Gmclist <
> about 25
> back
> > Christo Darsch
> > GMC Nor'easters
> > Weymouth, MA
The Digi-Panel sensor is a surface sensor, not a liquid sensor.
Christo Darsch
GMC Nor'easters
Weymouth, MA
My Digi-panel reads pretty close... considering each LED on the engine temp scale is 15F.
I have fuel injection using the the EBL system. It has its own temperature sensor and I generally have the WUD (What's Up Display) running on my
laptop for fun. I have a 180F thermostat which the EBL reports runs 180-185F and the Digi-panel shows the 175 to next LED higher lit.
I'm an electronics guy so of course I looked at the Digi-panel circuitry, but that was 6 or 7 years ago. There are no connectors from the sensors,
they are wired right to the board (unless that has changed). I remember one large trim pot in there, but I can't say I remember any other pots. The
circuitry appears to be circa 80's -90's, through-hole technology. It just uses the common bar-dot LED driver chips.
Here is the spec sheet on the IC's. From this you should be able to reverse engineer the circuit and adjust the input voltage to the IC.
https://www.ti.com/lit/ds/symlink/lm3914.pdf
Bruce Hislop
ON Canada
I'm not really an electronics guy, so if there isn't a trim pot for the temp sensors and there aren't any connectors that could increase resistance
(creating the low reading I'm seeing), I'm pretty much out of luck. Might just have to use it as suggested, as a guideline for what's normal. Thanks
though!
Christo Darsch
GMC Nor'easters
Weymouth, MA
I have a good VOM but I don't have the curves. I suppose I could call Applied and see if they have any of that info and are willing to share it --
they bought out the mfr a few years back.
Christo Darsch
GMC Nor'easters
Weymouth, MA
Thanks!
Christo Darsch
GMC Nor'easters
Weymouth, MA
I opened the case and found that there's a trim pot for all four gauges. Problem solved.
Christo Darsch
GMC Nor'easters
Weymouth, MA
As a rule the calibration remains without adjustment , but it could be the
thermocouple as we change part suppliers .
Call us if you need calibration so you can send it to our ave guys .
On Sun, Jun 7, 2020 at 10:35 AM Christo Darsch via Gmclist <
> Problem solved.
> Christo Darsch
> GMC Nor'easters
> Weymouth, MA
http://www.gmcrvparts.com
