Dead House Batteries
fred estabrook
84
---------- Forwarded message ----------
Date: Fri, Dec 16, 2016 at 7:01 PM
Subject: Dead House Batteries
To: "gmclist"
I have two dead house batteries and can't find out why they discharge. The
batteries are two years old and seem to hold a charge when they are not
connected. I have taken out the house fuses, checked the circuits but
there still seems to be a drain from somewhere in the system. I also
replaced the rear battery solenoid and checked the relay switch but still
no joy. The batteries were fine two days ago then suddenly went dead
overnight. The engine battery works fine. Any suggestions???
Fred Estabrook
76 Ell ( Lady K )
Florence AZ
Fred, disconnect ALL LOADS FROM THE HOUSE BANK. Recharge by a known good
source. Re connect one load at a time, and check discharge rate. What I
would do.
On Dec 16, 2016 6:06 PM, "Kathy and Fred Estabrook"
> From: Kathy and Fred Estabrook
> To: "gmclist"
> Fred Estabrook
> 76 Ell ( Lady K )
> Florence AZ
Another method is to fully charge the house batteries then connect a test
light between the negative terminal of the battery and the cable. ( the tip
of the light on one and the ground clip on the other) It will light if
there is a drain present. Individually disconnect circuits until the test
light dims dramatically or ideally goes out all together. Once you have
made the light go out or dim dramatically reconnect the circuits you have
removed until the only remaining ones are the ones which impact the light.
Investigate those remaining loads which are causing the light /drain.
Sully
77 eleganza 2
Seattle
> would do.
> Jim Hupy
> > To: "gmclist"
> The
> still
> > Fred Estabrook
> > 76 Ell ( Lady K )
> > Florence AZ
I helped one of our club members who also had a problem with her coach
batteries draining.
In the back where the house batteries are you have a 50amp circuit breaker
and a solenoid. When the boost switch is activated the solenoid bypasses
the 50 amp circuit breaker (takes a lot of amps to crank engine over) and
engages the front solenoid switch to enable the engine to start from the
rear batteries. On the rear solenoid there are four electrical connections
two large post for the battery cables and two smaller posts for the
switching wires. One of the smaller posts is grounded and the other post
supports the wire from the boost switch located up front on the dash. One
of the smaller post will have 12v power and if that post is where the boost
switch wire is connected you will have continuous power to the boost switch
therefore the front solenoid would be engaged and would drain your house
batteries. To check for this condition use either a meter to check for 12v
on the smaller post,use a circuit tester light or disconnect your engine
battery and try to start the engine without engaging the boost switch.
Since you did replace the solenoid I would check the connections.
http://www.harborfreight.com/612v-circuit-tester-with-5-ft-lead-61652.html
> Sully
> 77 eleganza 2
> Seattle
> > would do.
> > Jim Hupy
> > > To: "gmclist"
> > The
> > still
> > > Fred Estabrook
> > > 76 Ell ( Lady K )
> > > Florence AZ
> > > GMCnet mailing list
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
If you find you have dead house batteries check the converter first. After
many hours in the past three days checking solenoids and wiring I found the
problem was a drain from the converter.. I didn't check if first as it is
only 6 years old.
Many thanks to members on the net Jim Hupy, Todd Sulivan, Bruce Hart and
Bob Burkitt. What a great group. Thanks!!!!
Fred Estabrook
76 Ell (Lady K )
Florence AZ.
