Dave Lenzi's modified upper A arms to increase caster.
Bob Dunahugh
2,784
4
3
This replacement 78 Royale drives better then our last one. I pulled Dave's knuckles, relay arm, idler arm, and the new steering wheel slip joint out of the burned Royale. Plus the upper A arms that had the offset rubber bushings installed. Already installed the knuckles. Not the relay, idler arm, or slip joint yet. Thinking of putting in the reworked A arms that Dave makes. Caster is extremely important for having the GMC drive perfectly straight. His pair of A frames are about $750. Thinking that I'll order some from his next run later this year. Any input out there? Bob Dunahugh. 78 Royale
I don't think they may be necessary on 77-78. Dave looked at my stock upper cams and they were all dead center after Cinnabar worked on it. He told me
to crank the rear inboard and then go outboard with the front to keep camber neutral. It's a trade off game but I got 4 deg if I remember correctly
both sides as a stopping point and she drives great with standard bushings.
Bob,
The max caster possible on Double Trouble with Moog offset bushings in the rear positions of the upper control arms was 1.9 and 2.0
degrees. It wandered. After installing a set of Dave's upper control arms in Houston I was able to get 6.0 degrees which I dialed
back to 5.0. Double Trouble now steers like it was on rails.
HOWEVER, I had NOT checked the steering box to determine if it was on high center before I installed Dave's upper control arms.
As I understand it on later coaches (77 & 78) changes were made and it is possible to get more caster. On the 77 Kingsley John
Sharpe and I completely rebuilt the front end and installed Moog offset bushings. We also set the steering box on high center.
Unfortunately we ran out of time (I was flying back to Sydney) so we didn't have time to align the front end so I can't tell you how
much caster was possible. I won't be able to provide that info until I return to Houston (March 27).
The Pedantic Mechanic
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Bob Dunahugh
Sent: Tuesday, January 16, 2018 4:59 AM
Subject: [GMCnet] Dave Lenzi's modified upper A arms to increase caster.
In My 77 royale with stock upper arms and offset upper bushings I was able
to get a pair of fives for castor and it was a two finger driver pulling a
trailer.
And a sullybilt rear suspension kit.
Sully
77 eleganza 2
Bellevue.
On Mon, Jan 15, 2018 at 12:45 PM Rob Mueller
wrote:
> Bob,
> Regards,
> Rob M.
> Sydney, Australia
> Dunahugh
> To: gmclist
> Dunahugh. 78 Royale
I put a lot of Dave's parts in out first 78. Got it aligned. Did the same with a friend's 78. Both drove well. Just not as good as I thought they should. Bought this latest 78 with about 100,000 less miles that has all it's original parts. Drives better then the ones I fixed. It's got to be how the aligning is done. I know one other person that has had the same thing happen. Bob Dunahugh 78 Royale
Sent: Monday, January 15, 2018 11:59 AM
Subject: Dave Lenzi's modified upper A arms to increase caster.
Bob,
Re the two GMC's you put Dave's parts in please advise:
1) What was the front ride height set at?
2) What was the rear ride height set at?
3) What was the camber setting?
4) What was the toe setting?
5) What was the caster setting?
6) Was the steering box set on high center?
7) Were the relay lever and idler arm 90 degrees perpendicular to the front cross member when the steering box was set on high
center?
Sydney, Australia
Sent: Tuesday, January 16, 2018 2:59 PM
Subject: [GMCnet] Fw: Dave Lenzi's modified upper A arms to increase caster.
Royale
There is a coach around here that was owned by a city that didn't use it much but kept it well maintained.
This thing has the original steering shaft boot on it.
I got to drive it and it drove like a dream. It is an empty transmode, but still, it just drive like a car I tell you.
Sent: Tuesday, January 16, 2018 5:58:26 AM
Subject: Re: [GMCnet] Fw: Dave Lenzi's modified upper A arms to increase caster.
Bob,
center?
Sydney, Australia
Royale
Gerald Works. Thanks for the wakeup call. I've been aware of what you brought up. And on this latest 78. Just haven't thought of the rear as much as I should have. I had checked for rear pins condition by the pry bar method. And have paid close attention to how the coach handled as trucks passed by for rear steer. But I failed to check rear alignment. A few years ago I had the opportunity to drive an extremely low mileage 78. It handled like a new car. Ours now drives very close to perfect. Just not there yet. I just might have a slightly bent rear arm. Or as I said. The rear pins FELT good. I need to pull the arms/pins, and mic those parts. ( GREAT. More to take apart ) Thanks again for the wakeup. Bob Dunahugh. 78 Royale
Bob, an easy way to check for bent bogie arms is to jack up the rear of the
coach under the bogie boxes, and remove the wheels and tires. Then, use a
long accurate straight edge and hold it firmly against the mounting flange
where the studs come out on the rear bogie arm. Then look at the forward
bogie flange where the straight edge meets the flange. It should sit
squarely across the flange. If there is a gap on the front and not on the
rear of the flange, then the arm is bent towards the frame of the coach, or
towed in. Opposite gap would be towed out.
Bending is the remedy. If there is slop in the bushings, there is
wear, and the pins and bushings need to be serviced.
> From: Bob Dunahugh
> To: gmclist
