Hi Bob,
Yes, I was referring to the delay relay, at the very top of the compartment. I can send you my original one if you’d like. There are also a few NOS 366408 delay relays on eBay at present — I’d be happy to pick one up for you to repay your generosity with the spare carrier!
-Dave Stragand
1978 Transmode, near Pittsburgh
> There seems to be some miss understanding. The blower ( RELAY ) is new, and working properly. It's the blower motor ( DELAY ) that's not working. The DELAY is located just above the RELAY. The DELAY is so there are two vacuum controlled doors. Have time to get into their proper position before the blower motor turns on in the high position. As the vacuum controlled diaphrams can be overpowered by the blower. In 1977. GM made great improvements for the 77-78 modals in this area. James H mentioned that the engine needs to be running for the blower to run on high. This is important to remember. So. I had bypassed the delay. Everything then worked fine. And I understand that the DELAY is obsolete. Would it be hard to make a replacement ? The cooling part works great. When I built this 78. I put in a Sanden compressor, and hoses on that I got from Jim K at Applied. Very nice kit. Bob Dunahugh 78 Royale
> ________________________________
> From: Bob Dunahugh
> Sent: Tuesday, May 29, 2018 6:46 PM
> To: gmclist
> Subject: Dash heat, A/C blower motor delay.
> Mine quit working today. And from what I understand. They're obsolete. Any sparky out there have an idea on how to make one. Bob Dunahugh 78 Royale
