Should be able to use your stock compressor and condensor.
The compressor if leaking can be sealed of buy a rebuilt one with limited success. There has been reports of short time failure on the stock
compressor rebuilds?
I just completed my A/C changes. I switched to a sandeen compressor and bracket. About $400 worth. The advantage is it is effecient in the fact
there is virtually no engine load when it is kicked in. And the new bracket system is pretty clean/simple adjusting and does not block the valve
cover.
Anyway - search ebay for the aux evaporator. There is a bunch of china- knock off evaporators from $70 and up to a couple hundred.
The other item is the hoses and fittings to connect everything up. A/c hose can be $5 a foot and each hose end can be $10. You need a crimper or
you can always have a hose made locally for a significant amount of money.
Good luck. I will post some photos at some point, but I literally and finishing it today(wire in binary switch). And i am pretty happy with it, but
it needs a good test yet in how well it will work.
One comment, is I looked at adding some other evaporators, but having it blow from near dash allows me to aim the air on me.
I know of an aux unit under a dinette. And it works great but driver is hot for a long time during when the coach first starts Until the whole coach
cools off. Good for long trips. Not ideal for quick ones.
Jon Roche
75 palm beach
St. Cloud, MN
