Dash ac oil
LarryW
6,041
765
113
Menomonie, WI.
My dash AC has been making a "clunking" sound lately. Asked an AC guy about it and he said that it likely needed some more AC oil. (my word not his).
How much should I add and how?
Thanks
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Larry, oil type depends upon your installed refrigerant. R12 and HC12a use mineral oil, NAPA TEM 209500. R134a use ester oil. The oils are not
compatible. If you have converted to R134a, you can go anywhere (Wal-Mart, Menards, auto parts stores) and purchase a can that goes in the low port.
I don't know about installing mineral oil. I do need to know. I need to install new A6.
Tom, MS II running the Honda and the overhead air.
1975 GMC Avion
KA4CSG
Tom, R134 systems use PAG oil, if they were installed by a shop that
flushed the system or in newer cars. PAG oil is indeed not compatible with
mineral oil used in R12 systems. But ester oil is compatible with both.
Ester oil is an alternative for systems converted from R12 that might have
traces of mineral oil in them.
Larry, if it just needs a little, you can get a can of refrigerant with the
oil mixed in, but only R134 these days. If you are using HC12A/Duracool,
both mineral and ester oil will work, but ester oil might be the safer bet
if you don't know what's in it and it just needs to be topped up. You can
evacuate the system and pour the oil right into the back of the compressor.
I seem to recall (and this is a fuzzy memory) that only a pint is used in
the system and maybe even less (I'm visualizing the bottle in my dim memory
and it might have been 10-12 ounces), so it should not take much to top it
off. But you'll have to open the system. The question is: Where did the oil
that was in it go? Losing compressor oil isn't common.
Rick "who, come to think of it, needs to charge his system and see if it
works" Denney
> install new A6.
> 1975 GMC Avion
> KA4CSG
'73 X-Glacier 230 "Jaws"
Northern Virginia
Mineral oil is available at any HVAC supplier warehouse and some decent auto parts stores. I seriously doubt that this is the source of your noise.
I would look at the heater fan. That fan will loosen up on the shaft, wear, and clunk. Auto Zone has new ones.
If you're looking to get R12 Refrigerant Oil charge. it's still readily available on ebay. Here's just one auction I found, but if you search for R12
refrigerant oil, there are quite a few auctions:
http://www.ebay.com/itm/Refrigerant-R12-Oil-Charge-4oz-MFG-Sercon-part-6512-/122556242943?hash=item1c88ebdbff:g:50IAAOSwAuZX1c1O&vxp=mtr
It's a little pricey, but not terribly expensive. As a guy who lives in Texas and has several older vehicles with R12 AC, there are more "deals" on
R12 related stuff if you shop during the winter... ;)
You can also often find R12 locally on Craigslist as well...
Mark S. '73 Painted Desert,
Manny 1 Ton Front End,
Howell Injection,
Fort Worth, TX
OK...Thanks all for the replys. I have a Duracool system and talked to a Midwest Classics member that does AC for a living. He told me to add 4oz of
ester into the system with a new Dryer.
Ken, the "clunking" noise that I described is definitely not the fan...checked that out. Noise is only there when AC compressor clutch engages, and
goes away when engine speed increases. Friend told me he had heard it many times and easiest check is to just add some oil to the system. So I'm gonna
just pour 4 oz into the dryer, vac it down and recharge. I pulled a vac on it this morning and held 29" for 1/2 hr, so system is tight.
Anyway...thanks all.
Larry
Menomonie, WI.
> 4oz of ester into the system with a new Dryer.
> and goes away when engine speed increases. Friend told me he had heard it many times and easiest check is to just add some oil to the system. So I'm
> gonna just pour 4 oz into the dryer, vac it down and recharge. I pulled a vac on it this morning and held 29" for 1/2 hr, so system is tight.
Well, So much for my guess at the problem. My only problem with adding oil is it is possible too load up the dryer with excess oil from the system.
It should not need oil unless some of it has leaked out. If it leaked then you will also be low on freon.
I ran into a problem once on Dan Gregg's coach. It only happened when the clutch was engaged. It turned out that it had a belt that was too long
allowing the clutch to slightly drag on the cross brace next to it. I believe you have a Cadillac engine so this probably does not apply to you.
> > add 4oz of ester into the system with a new Dryer.
> > engages, and goes away when engine speed increases. Friend told me he had heard it many times and easiest check is to just add some oil to the
> > system. So I'm gonna just pour 4 oz into the dryer, vac it down and recharge. I pulled a vac on it this morning and held 29" for 1/2 hr, so
> > system is tight.
> system. It should not need oil unless some of it has leaked out. If it leaked then you will also be low on freon.
Ken, for various reasons, I've had to drain and refill the system about 4 times in the last year. Oil has come out each time. I'm hoping that all it
needs is a little oil. Will be adding 4oz today sometime. Thanks for the suggestions though. Every little thought helps.
Larry
Menomonie, WI.
Oil charge cans are the obvious fast easy way to go here. If really low causing the noise, adding One can should clear it up. More is not better at it
starts to take the place of refrigerant. It's often found on eBay as R12 oil charge if you are running R12 or added HC12 to an R12 system. Auto parts
store if running 134a.
Larry you really need too know if it has pag oil ester oil or mineral oil in the system you don't want to mix mineral with the first two. I believe
the dura cool people say they have an oil that is compatible with all three of these but that is all I know about it.you may want too call them.
Roy Keen
Minden,NV
76 X Glenbrook
> believe the dura cool people say they have an oil that is compatible with all three of these but that is all I know about it.you may want too call
> them.
Roy,
I have a half of a can of ester in with my AC stuff, so it is safe to assume that this is what is left over from the last time I added oil. Thanks
for the comment.
Larry
Menomonie, WI.
If you still have cold air it is very unlikely you are low on oil. You might check the lines and see if there is any signs of refrigerant oil around
the fittings.
A possible cause of your "Clunk" could be that the compressors clutch is out of adjustment. I believe the procedure is in the service manual, but it
does take special tools to make the adjustment.
> around the fittings.
> it does take special tools to make the adjustment.
OK, I'll check that too. Thanks!!
Larry
Menomonie, WI.
Single clunk most likely clutch and some noise is normal. Hammering at running speed is normal if faint and abnormal if loud. I have had luck with
reducing noise on A6 and R4 w R12 by adding a single small can of oil charge. You can do the matchbook test as a rough initial check of compressor
clutch gap while off and not running.
