Dana?
ron & gina
397
Hi all,
Cleared all obstacles from in front of radiator, now have clear air path
hope it helps! Got to see the name on air compressor it was Hadley
products(on compressor housing)? Is this a Dana? If not does anyone know if
the Dana O/H kit still works on this model? It looks identical to the
pictures of the Dana with cross over, motor over middle "V"(Is this a Harley
design) of both heads, Blue belt cover with direction arrow at top except
there's a round picture of a man holding something and has Hadley products
on it.
Also looks like Radiator will come out pretty easy, Remove both hoses,
tranny/oil tubing into radiator, four bolts on radiator top cage cover and
loosen top A/C and tranny cooler mounting bolts(both coolers attached to
same mounting bracket) remove bottom two and tilt out which should allow
enough room to slide radiator up and out front on my coach without raising
coach, Atleast I hope so will find out soon. Thanks for any info!!
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave. AZ.
