Dana rebuild kits
Feb 6, 1999
135
Emery John Clement at(909) 737-0969 has kits, belts and individual parts. he
will also overhall, exchange,etc.
Bill 76Edgemont
> I decided that my Dana needs rebuilding. I have no leaks and everything
> holds air properly. I put Cinnabar's filter kit on several years ago. The
> problem is that it is taking so long to pump up. Much longer than it used to.
> I called Cinnabar, Gateway, GMC Coop (Jim Bounds), Alex Sirum and Golby.
> None had the kits anymore. I was told that the kits are no longer being
> made. Golby said they had some pistons with rings and also some valves in
> stock. I then called Osbornes in Albuquerque. They have some kits left in
> stock. The price is around $65.00.
> If anyone wants to get a kit before they totally disappear you might call
> Osborne at 505-821-0543.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
Got my rebuild kit from Gateway in January for 48.50. Glad I did
because others were already out.
By the way, Emery, when I did the rebuild I found that one of the
shafts was broke off at the crank. No wonder it was slow (1-banger).
To my total suprise, new shafts were available from at least 2
suppliers. Got shaft from Cinnibar and now it works fine. Also, found
Patrick's pictures very helpful.
Good Luck,
Bill
'74 Glacier
Do You Yahoo!?
>everything
> The
>used to.
>Golby.
>being
>valves in
>left in
>call
>Emery Stora
>77 Kingsley
>Santa Fe, NM
Somebody has been pulling your leg. John Clement in Corona, CA sells
these kits by the hundreds a and puts on a great rebuild tech session at
rallys. You will find him in the GMC MI roster.
David Lee Greenberg F22009
GMC Motorhome Registry
200 MacFarlane Drive PH4
Delray Beach, FL 33483-6829
